New solver and Segmentation fault (core dumped) |
August 26, 2021, 04:33 |
#1 | |
MinShin Kwon
it's first time to write a thread for handling my big obstacles. From last month, I put my effort to be familiar with code development for my MS degree. And, this is what I have done for new solver and the bad result. ----------------------------------------------------------------------------------- <New solver for checking> I have modified icoFoam standard solver, giving it New solver name (1) Using command "cp -r", I copied icoFoam to $USER/application/solver (2) Change directory name from "icoFoam" into "icoTFoam" (3) Command "wclean" (4) Change code source file name from "icoFoam.C" into "icoTFoam.C" (5) Directory context modification Make>files => Change file context "icoFoam.C" into "icoTFoam.C" Make>files => Change file context "$(FOAM_APPBIN)" into "$(FOAM_USER_APPBIN)" (6) And command "wmake" for compiling New solver (7) Applying "icoTFoam" solver to several tutorial example, but NOT useful. ===> I just got this message on terminal screen : Quote:
As you can understand, I just changed solver name and location of files for the new solver. But, I just got this message. (##I also tried same process in the case of other standard solver too, for double checking, but anything get better##) Plz, let me solve this issue for developing further New customized solver. Thank you for reading. |
August 27, 2021, 16:34 |
Custom icoFoam
Drupada Roy
Hey, may be I can help you. Just follow the steps of this link.
https://www.google.com/url?sa=t&rct=...ocmPzLso5RFn_8 But may be, you want to change the name only. Just follow the 1st few steps. Hope it will solve your problem! Best wishes. |
August 30, 2021, 06:04 |
MinShin Kwon
Hello, Roy.
I was thirsty for reply to this problem, and you did it. Thank you for your kindness. I follow the process described at the link you referred to. BUT, sadly, consequences is same as before...... |
Segmentation fault (core dumped) | Sugajen | OpenFOAM Running, Solving & CFD | 1 | August 2, 2017 12:06 |
Segmentation fault (core dumped) | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 4 | March 13, 2017 20:06 |
Segmentation fault (core dumped) | NH1994 | OpenFOAM Pre-Processing | 0 | January 9, 2015 03:20 |
Segmentation fault (core dumped) | NH1994 | OpenFOAM Programming & Development | 0 | January 9, 2015 01:24 |
Segmentation fault (core dumped) when changing pressure BC | jptorol | OpenFOAM Running, Solving & CFD | 0 | September 25, 2013 18:05 |
