August 24, 2021, 14:30 |
wallHeatFlux for multiphase flows
Rep Power: 9 |
Hi everyone,
currently, the postProcessing function object for the wallHeatFlux with icoReactingMultiphaseInterFoam does not work (see https://develop.openfoam.com/Develop.../-/issues/1820). the error is: Unable to find compressible turbulence model in the database Is there any other way to compute the heat flux for a multiphase flow in OpenFoam? Many thanks |
January 25, 2024, 05:40 |
marcus aurelius
Rep Power: 3 |
I am facing the same problem. Did you find the solution?
heat flux, icoreactinmultiphaseif, wallheattransfer |
OF 6 wallHeatFlux utility not working on chtMultiRegionFoam tutorial | troparry | OpenFOAM Post-Processing | 1 | January 10, 2022 07:12 |
QGDsolver - OpenFOAM computational framework for fluid flows based on regularized equ | mkraposhin | OpenFOAM Announcements from Other Sources | 7 | September 13, 2021 04:09 |
wallHeatFlux and y+ | dasbrot | OpenFOAM Post-Processing | 0 | March 13, 2021 07:23 |
Bug or feature in wallHeatFlux calculation for patches?? | DaveD! | OpenFOAM Post-Processing | 0 | April 6, 2020 09:14 |
wallHeatFlux utility with sonicFoam | hiuluom | OpenFOAM Post-Processing | 3 | September 18, 2015 08:39 |
