Dynamic Mesh issue concerning rotation in rhoCentralFoam/sonicFoam
Like Tree1Likes
  • 1 Post By emjaey3590
Old   August 11, 2021, 04:38
Default Dynamic Mesh issue concerning rotation in rhoCentralFoam/sonicFoam
manoj
emjaey3590 is on a distinguished road
Hello Foamers,
I am trying to use supersonic compressible solver (rhoCentralFoam/sonicFoam) to simulate flow across a bullet, which has a rotational motion (dynamicMeshDict). The bullet used is a stl file, henceforth I used snappyHexMesh to generate the Mesh. The arbitrary mesh interface (AMI) is also introduced in the simulation to enable simulation across disconnected, adjacent, mesh domains.
The boundary condition used for pressure (p) is:
For inlet, walls, bullet wall I have used "zeroGradient" boundary condition.
For outlet I have used "waveTransmissive" boundary condition.
For AMI I have used "cyclicAMI" boundary condition.
The boundary condition used for velocity (U) is:
For inlet "supersonicFreestream" is used.
For outlet "inletOutlet" is used.
For bullet "movingWallVelocity" is used.
For walls "zeroGradient" is used.
For AMI "cyclicAMI" is used.
The boundary condition used for temperature (T) is:
For inlet and outlet "inletOutlet" is used.
For walls and bullet wall "zeroGradient" is used.
The fvSchemes and FvSolution that I have used is same as that of the tutorials that are provided for rhoCentralFoam and sonicFoam.
But when I try to launch the simulation, it runs for few iterations and finally fives the error mentioned below
--> FOAM FATAL ERROR:
Negative initial temperature T0: -26.69115
    From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
#3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
#4  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam"
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam"
^C
[1]+  Aborted                 (core dumped) rhoCentralFoam > log
Would somebody be kind enough to help me solve this problem.
thunde47 likes this.
emjaey3590 is offline   Reply With Quote
Old   March 19, 2022, 23:29
Jonathan is on a distinguished road
Originally Posted by emjaey3590 View Post
Hello Foamers,
FOAM aborting
^C
Not sure if you solved this, but I have found with compressible simulations (rhoCentral and others) that time step size is really important. I often get (got) negative temperatures as soon as the shocks started forming if my Courant number was too high. Using adaptive time stepping based on Co number really helped, otherwise reducing the timestep to something smaller usually helps.
The other thing which people sometimes miss is to check your fluid properties - if you have an error and you try to do sonic flow, you're going to get funny results. For instance, make sure if you copy transportProperties / thermoPhysicalProperties from another case they are correct for your set up.
Hope it helps.
Jonathan is offline   Reply With Quote
amicyclic, dynamicmeshdict, rhocentralfoam, sonicfoam
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
UDF CG_MOTION rotation dynamic mesh Mads FLUENT 2 April 15, 2014 04:30
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Postprocessing issue with dynamic mesh? ghost82 FLUENT 1 November 2, 2012 11:06
