August 4, 2021, 13:31 |
rhoSimpleFoam accuracy
Rep Power: 6 |
Hello guys,
I am calculating a centrifugal fan with rhoSimpleFoam as solver. The problem is I cannot get so accurate value as I have with CFX. The pressure still to low with OpenFoam (20% lower compared to CFX). My mesh should be OK according to checkMesh. Coud you tell me if you see something wrong in my configuration ? fvSchemes : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear 1; // grad(U) cellMDLimited leastSquares 1; // grad(p) cellMDLimited Gauss linear 0.33; } divSchemes { default Gauss upwind; div(phi,U) Gauss linearUpwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,e) Gauss linearUpwind grad(e); div(phi,Ekp) Gauss linearUpwind grad(Ekp); } laplacianSchemes { //default Gauss linear corrected; default Gauss linear limited 0.777; } interpolationSchemes { default linear; } snGradSchemes { //default corrected; default limited 0.777; } wallDist { method meshWave; correctWalls true; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(p|e)" { solver GAMG; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 1000; agglomerator faceAreaPair; mergeLevels 1; tolerance 1e-6; relTol 0; nPreSweeps 1; nPostSweeps 2; minIter 4; maxIter 200; } "(k|omega|rho|U)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-9; relTol 0; maxIter 50; minIter 5; } /* "(k|omega|rho)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-10; relTol 0; maxIter 50; minIter 5; solver smoothSolver; smoother GaussSeidel; tolerance 1e-10; relTol 0; maxIter 50; minIter 5; }*/ } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; nCorrectors 4; pMinFactor 0.1; pMaxFactor 2; consistent yes; residualControl { /* p 1e-3; Ux 1e-3; Uy 1e-3; Uz 1e-3; omega 1e-3; k 1e-3;*/ } } relaxationFactors { fields { p 0.9; rho 0.1; } equations { U 0.8; //0.7 e 0.7; "k|omega" 0.65;//0.2 } } // ************************************************************************* // thermophysicalProperties : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture // air at room temperature (293 K) { specie { molWeight 28.9; } thermodynamics { Cp 1008; Hf 0; } transport { mu 1.82e-05; Pr 0.99; } } // ************************************************************************* // I attached a screenshot of the mesh and the residuals. Thank you in advance ! |
August 5, 2021, 07:25 |
Daniel
Rep Power: 5 |
Hey Fouch,
can you also share you 0 Folder (BC´s)? I am also using rhoSimpleFOam for my Case and it behave´s not always as intended. |
August 5, 2021, 08:53 |
Rep Power: 6 |
August 6, 2021, 08:00 |
Rep Power: 7 |
Is your case is more a blower than a compressor? What is pressure ratio magnitude are you expected? Because that is strange, in my case OpenFOAM over-estimates my pressure ratio but the magnitude is quite close (from my point of view).
I think… that the problem comes from the energy equation that is not suitable in MRF Anyway, this is my last fvSolution and fvSchemes, if it might help fvSolution Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { Phi { solver GAMG; smoother DIC; tolerance 1e-06; relTol 0.01; } "(p|rho)" { solver GAMG; tolerance 1e-08; relTol 0.05; smoother symGaussSeidel; nCellsInCoarsestLevel 200; } "(U|k|epsilon|omega)" { solver smoothSolver; smoother symGaussSeidel; nSweeps 2; tolerance 1e-06; relTol 0.1; minIter 1; } "(e|h)" { solver PBiCGStab; preconditioner DILU; nSweeps 2; tolerance 1e-06; relTol 0.1; minIter 1; } "(p|rho)Final" { $p; tolerance 1e-06; relTol 0; minIter 1; } "(U|k|epsilon|omega)Final" { $U; tolerance 1e-05; relTol 0; minIter 1; } "(e|h)Final" { $e; tolerance 1e-05; relTol 0; minIter 1; } } limiters { pMinFactor 0.01; pMaxFactor 5; } potentialFlow { nNonOrthogonalCorrectors 0; } SIMPLE { consistent yes; // to use SIMPLEC transonic yes; nNonOrthogonalCorrectors 0; // 0 to 20 $limiters residualControl { p 1e-4; U 1e-5; "(e|h)" 1e-5; "(k|epsilon|omega)" 1e-4; } } relaxationFactors-SIMPLE { fields { p 0.3; rho 0.05; } equations { p 1; U 0.7; "(e|h)" 0.5; "(k|epsilon|omega)" 0.7; ".*Final" 1.0; } } PIMPLE { nOuterCorrectors 2; nCorrectors 1; nNonOrthogonalCorrectors 0; $limiters } relaxationFactors-PIMPLE { equations { U 0.95; "(e|h)" 0.95; "(k|epsilon|omega)" 0.95; ".*Final" 1.0; } } // relaxationFactors { $relaxationFactors-PIMPLE } relaxationFactors { $relaxationFactors-SIMPLE } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes // <optionalLimiter> <gradientScheme> <interpolationScheme> { default Gauss linear; limited cellLimited Gauss linear 1; grad(U) $limited; grad(k) $limited; grad(epsilon) $limited; grad(omega) $limited; } divSchemes // Gauss <interpolationScheme> { default none; div(phi,U) bounded Gauss linearUpwind limited; div(U) Gauss linear; div(div(phi,U)) Gauss linear; // for potentialFoam div((nuEff*dev2(T(grad(U))))) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; energy bounded Gauss linearUpwind limited; div(phi,e) $energy; div(phi,h) $energy; div(phi,K) $energy; div(phi,Ekp) $energy; div(phid,p) Gauss upwind; div((phi|interpolate(rho)),p) bounded Gauss upwind; turbulence bounded Gauss upwind; div(phi,k) $turbulence; div(phi,epsilon) $turbulence; div(phi,omega) $turbulence; } laplacianSchemes // Gauss <interpolationScheme> <snGradScheme> { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; correctWalls true; // OPT correct distance from near-wall cells to the boundary } |
August 7, 2021, 18:04 |
Rep Power: 6 |
Thank you for your feedback. Yes, in my case it’s more a blower. The expected static pressure ride is 5,5kPa. I see that you use transonic option. I have never tested. May be you are right and the solver is not suitable for MRF but that would be a pity… Could you share your thermoPhysical file too ? Thank you |
August 9, 2021, 07:23 |
#6 | |
Rep Power: 7 |
https://www.youtube.com/watch?v=hBQUcaPHbk4 My thermophysical properties are already described in my previous post Issues on the simulation of high-speed compressible flow within turbomachinery and I have already tried many fluid models but the results didn't significantly change. |
August 9, 2021, 09:39 |
Rep Power: 6 |
Hi !
Thank you Anthony. I will retry with simpleFoam but next week (no computer this week). I keep you in touch. |
September 8, 2021, 06:46 |
Rep Power: 6 |
Below my feedback after some tests : Steadystate calculation : Difficult to keep stable results event with consistent option activated (SIMPLEC). LTS (Local Time Step) I am using this discetisation now and it is really more stable. I can use komegaSST crash and the results are accurate enough. anthony761, Have you ever tried LTS for the computation of your compressors ? |
October 25, 2022, 11:36 |
Compressor blade Simulation
#9 | ||||
Sakun
Rep Power: 7 |
Hi guys i am having the same issues like above discussion.
I am running a high speed compressor blade simulation using rhoSimpleFoam and my pressure values are not getting converge. Also i am having strange pressure values as well. U file Quote:
can someone help me on this |
Starting from 1st order accuracy and continue to 2nd order accuracy | elochana | FLUENT | 1 | June 20, 2021 19:22 |
Time integration order of accuracy when solving acoustic wave equation using FEM | lzhaok6 | Main CFD Forum | 20 | May 3, 2017 12:22 |
rhoSimpleFoam angledDuctExplicitFixedCoeff tutorial fails in parallel | donQi | OpenFOAM Running, Solving & CFD | 1 | February 22, 2016 20:47 |
Temporal accuracy | ganesh | Main CFD Forum | 0 | February 29, 2008 06:32 |
accuracy of Discontinuous Galerkin | Qu Kun | Main CFD Forum | 0 | September 6, 2004 10:19 |
