fieldFunctionObject all region
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By HorstvanGrass
Old   July 26, 2021, 17:23
Default fieldFunctionObject all region
Horst van Gras
HorstvanGrass is on a distinguished road
i have a multi region simulation and working on some postprocess routines. However I have to specify each time the region to get the value. However, I would like to have the functions looping over all regions.
functions
        CellVolumeSteel
                // Mandatory entries (unmodifiable)
                type            writeCellVolumes;
                libs            (fieldFunctionObjects);
                // Optional (inherited) entries
                region          steel;
                enabled         true;
                log             true;
                executeControl      writeTime;
                writeControl        writeTime;
Is there a kind of command like 'allRegion'?
HorstvanGrass is offline   Reply With Quote
Old   July 27, 2021, 04:34
Yann
Yann will become famous soon enoughYann will become famous soon enough
There is a new multiregion function object allowing to do this in the latest ESI-OpenCFD release (OpenFOAM-v2106) : https://www.openfoam.com/news/main-n...ng#multiregion
AFAIK, there is nothing similar in the older versions nor in the foundation branch, but I would be happy to know if somebody else has a solution for this.
As a workaround to save you a little bit of time, you can do something like this in order to avoid duplicating the function definition:
functions
    CellVolumeSteel
            region            steel;
            enabled         true;
            log             true;
    CellVolumeRegion2
        $CellVolumeSteel
        region                region2;
Another way around would be to write a script yourself to loop over all the regions and automatically generate the proper code. It could be worth spending to write such a script if you have a lot of regions in your case.
Cheers,
Yann
HorstvanGrass likes this.
Yann is offline   Reply With Quote
Old   July 28, 2021, 11:30
Horst van Gras
thanks for this. It works like a charm with ESI Toolbox version2012. I have 3 regions. Therefore I don't think that I will code a loop
This new function is indeed quite useful. But I will have to adapt my custom solver to it.
Yann likes this.
fieldfunctionobjects, multiregion, postprocess
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 09:12
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 07:51
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
