Interesting Flow Problem - after a while the solution gets totally destroyed
Like Tree3Likes
  • 2 Post By NiklasW
  • 1 Post By Yann
Old   July 1, 2021, 10:52
Default Interesting Flow Problem - after a while the solution gets totally destroyed
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hey foam community,
I might ask you an interesting question. I attached a case (nothing special) a room with a window. The window does not play a big role right now. The top wall (ceiling) is heated to 300 K. The bottom is set to 295 K. Hence, I expect a uniform temperature layering from bottom to top and almost no flow. The only interesting point is that the room is a closed volume (no inlets/outlets). The facts are:
  • Without turbulence model the case crashes after two/three iterations
  • With turbulence model it works (guess due to the artificial diffusion)
    • However, the temperature rises - for any reason > 300 K (around 380 K) - no Idea why that happens.
    • Solution is not physical (at least the temperature does not make sense at all)
    • Schemes are upwind
    • Mesh is pure hex-mesh (no orthogonality)
Even with 10 years FOAM experience, this simple test case makes me getting crazy but I guess I just made some small mistake. An interesting point is, that p and p_rgh is initialized by 1e5 Pa but the results show me 0 Pa. Is it related to the closed volume? Probably it shouldn't. At least the p field should have 1e5 Pa as we use it for calculating the density (even though I use incompressiblePerfectGas )
Case is given for v8.
https://Holzmann-cfd.com/forum/room.tar.gz
Any ideas?
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   July 1, 2021, 11:43
NiklasW is on a distinguished road
Have you tried to use a different equation of state?
I haven't looked deeply into your case, but at first glance I'd say incompressible perfect gas might cause some problems in a closed system, because it calculates density independent from pressure.
Tobi and Yann like this.
NiklasW is offline   Reply With Quote
Old   July 1, 2021, 12:27
Yann
Yann will become famous soon enough
Hi Tobias,
I think your 0 Pa pressure is related to the pRefValue in fvSolution:
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
Since you have a closed volume there is no pressure value defined on any patch and the solver should look for a pRefCell and pRefValue in fvSolution.
Not sure how it affects the solution though.
Yann
Tobi likes this.
Yann is offline   Reply With Quote
Old   July 1, 2021, 13:02
Tobi's Avatar
Tobias Holzmann
Hey both.
  • the incompressiblePerfectGas was the mistake (my fault) - thanks for the hint and you are totally correct. This will destroy the solution
  • the pRef data in the fvSolutions is correct too. However, after changing the EOS, these data are not used anymore.
So ... thank you!
Keep foaming,
Tobias Holzmann
Old   July 1, 2021, 13:16
Tobi's Avatar
Tobias Holzmann
Okay now we are ready to go to discuss. By using the case provided and changing the EOS to perfectGas, everything works (even though the velocity field looks weirdo - probably based on the steady-State analysis).
However, if we deactivate the turbulence model and calculate in a laminar manner, the temperature goes to 350 K. I have no idea why. That`s actually something I am not sure about.
Keep foaming,
Tobias Holzmann
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
Mass flow rate history over solution step- rhoSimpleFoam gian93 OpenFOAM Post-Processing 0 December 8, 2019 11:20
Two Mass flow inlet bc convergence problem nabidinhomessi Main CFD Forum 5 December 14, 2015 08:11
Newbie to compressible, viscous flow. Advice on approach to problem? bzz77 Main CFD Forum 4 December 4, 2012 08:59
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
