June 25, 2021, 15:26 |
Increasing Inlet Flow Velocity Over Time
n/a
Rep Power: 6 |
Hello all, I have what should be a relatively simple question. I am simulating the flow over three cylinders to observe the vortex shedding. I am currently using a constant inlet velocity, but I would now like to increase the inlet velocity over time.
In 0/U, I currently have the code: Code:
inlet { type uniformFixedValue; uniformValue constant (1 0 0); } outlet { type pressureInletOutletVelocity; inletValue uniform (1 0 0); value uniform (1 0 0); } In order to increase the inlet velocity over time, I believe I will modify "inlet" as e.g. Code:
inlet { type uniformFixedValue; uniformValue table ( (0 (1 0 0)) (5 (2 0 0)) (10 (3 0 0)) ); } My question is this – do I need to make a similar modification to outlet? It would just be this simple? Code:
outlet { type pressureInletOutletVelocity; inletValue table ( (0 (1 0 0)) (5 (2 0 0)) (10 (3 0 0)) ); } Last edited by williamsj0165; June 25, 2021 at 15:29. Reason: I have ended closing parentheses to the table values. |
June 25, 2021, 16:23 |
Simulation Running
n/a
Rep Power: 6 |
I have got the simulation running by modifying outlet as such:
outlet { type pressureInletOutletVelocity; inletValue table ( (0 (1 0 0)) (15 (2 0 0)) (30 (3 0 0)) ); value uniform (1 0 0); } |
inlet, velocity |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 14:38 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
