June 22, 2021, 08:48 |
buoyantSimpleFoam Error
Ataberk
Rep Power: 7 |
I try to solve a steady, turbulent, incompressible and heat transfer problem. In a rectangular shape, there are 13 batteries. And they have a heat flux value. In all heat transfer models, I have to change the compressible file to incompressible. Therefore, I always make mistakes. In this study, I used buoyantSimpleFoam. There are some problems while writing the necessary input. And I got this error. What should I do? Maybe, you can suggest another solver (probably you will say chtMultiRegion) or we can talk about changing compressible file to incompressible (I don't think it's such an easy matter that I can replace density only.) And also, I want to add thermophysical properties file. Maybe, I have to change something in this file. Thanks! Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { specie { molWeight 28.96; } thermodynamics { Cp 1004.4; Hf 0; } transport { mu 1.831e-05; Pr 0.705; } } // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: Convergence criteria found p_rgh: tolerance 0.001 U: tolerance 0.0001 h: tolerance 0.0001 "(k|epsilon|omega)": tolerance 0.005 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { model kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Creating thermophysical transport model Selecting thermophysical transport type RAS Selecting default RAS thermophysical transport model eddyDiffusivity Reading g Reading hRef Calculating field g.h Reading pRef Reading field p_rgh No MRF models present Radiation model not active: radiationProperties not found Selecting radiationModel none No finite volume options present Starting time loop Time = 1 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 0.00536049, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.999989, Final residual = 0.0037206, No Iterations 7 time step continuity errors : sum local = 0.269408, global = -0.00834916, cumulative = -0.00834916 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.0321705, Final residual = 7.80071e-06, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 0.000295899, No Iterations 1 ExecutionTime = 0.46 s ClockTime = 0 s Time = 2 DILUPBiCGStab: Solving for h, Initial residual = 0.026843, Final residual = 0.000173081, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.892057, Final residual = 0.00336125, No Iterations 3 time step continuity errors : sum local = 766.721, global = -4.69339, cumulative = -4.70174 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.740648, Final residual = 0.000894831, No Iterations 1 bounding epsilon, min: -335.513 max: 60702.7 average: 189.468 DILUPBiCGStab: Solving for k, Initial residual = 0.983617, Final residual = 0.000904046, No Iterations 1 bounding k, min: -6.35689 max: 628.844 average: 10.4528 ExecutionTime = 0.59 s ClockTime = 0 s Time = 3 DILUPBiCGStab: Solving for h, Initial residual = 0.0810137, Final residual = 0.000642639, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.931238, Final residual = 0.00480081, No Iterations 5 time step continuity errors : sum local = 929.728, global = -13.246, cumulative = -17.9478 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.854529, Final residual = 0.000398156, No Iterations 1 bounding epsilon, min: -1834.41 max: 381686 average: 1660.7 DILUPBiCGStab: Solving for k, Initial residual = 0.63389, Final residual = 0.000277833, No Iterations 1 bounding k, min: -113.523 max: 7561.63 average: 67.972 ExecutionTime = 0.71 s ClockTime = 1 s Time = 4 DILUPBiCGStab: Solving for h, Initial residual = 0.47617, Final residual = 0.00421619, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" #8 Foam::fvMatrix<double>::solve() in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" #9 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/buoyantSimpleFoam" Floating point exception (core dumped) |
June 22, 2021, 09:17 |
Herpes Free Engineer
Rep Power: 13 |
- try another turbulence model. sometimes epsilon of the kEpsilon model destabilises the computation.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
buoyantsimplefoam, chtmultiregionfoam, heat transfer, openfoam |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
