ON
Rep Power: 5 ![]() |
Hi foamers,
I am new to OpenFoam. To find all possible options for a parameter, I need to check the related source codes. How can I find them? For example, I would like use multiphaseEulerFoam to solve fluidized bed. In constant folders, there is a phaseProperties file, where I need to define phases. To define phase particles, I need to specify parameters, including type, diameterModel, constantCoeffs, alphaMax and residualAlpha. Code:
particles { type purePhaseModel; diameterModel constant; constantCoeffs { d 275.0e-6; // mean particle diamter } alphaMax 0.63; // maximum allowable packing fraction residualAlpha 1e-6; } Thank you very much! |
Rep Power: 15 ![]() |
Common methods include the "banana trick" (https://openfoamwiki.net/index.php/O...de/Use_bananas) -- e.g. to see what options are available for a given model input -- and foamSearch (https://cfd.direct/openfoam/user-gui...se-management/) -- e.g. to parse through the tutorials, I'd think. Otherwise, grep/find are always your friends (e.g., grep -r inletOutlet).
Caelan
Public git repository : https://github.com/clapointe2011/public |
#3 | |
ON
Rep Power: 0 ![]() |
The command "foamInfo xxx" will solver most problems, which often leads to "OpenFOAM/src/xxx" directory you can learn a lot about.
source code |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
