scotch parallel run is not working in OpenFOAM 2012 |
June 7, 2021, 07:24 |
chandra shekhar pant
Rep Power: 16 |
Hello Experts,
I installed OpenFOAM 2012 in my workstation, it is working fine while running with a single processor, but when I am trying to run it with 10 processors using scotch decomposition method it is giving me error which says: Code:
--> FOAM FATAL ERROR: You are trying to use scotch but do not have the scotchDecomp library loaded. This message is from the dummy scotchDecomp stub library instead. Please install scotch and make sure that libscotch.so is in your LD_LIBRARY_PATH. The scotchDecomp library can then be built in src/parallel/decompose/decompositionMethods/scotchDecomp From function virtual Foam::labelList Foam::scotchDecomp::decompose(const Foam::polyMesh&, const pointField&, const scalarField&) const in file dummyScotchDecomp.C at line 113. FOAM exiting |
June 8, 2021, 14:29 |
Klaus
Rep Power: 22 |
either scotch is not installed or it's not in the LD_LIBRARY_PATH of your system. Scotch is part of the "ThirdParty" software. If you look at the OpenFOAM source code you'll see that there are two download packages, "OpenFOAM" and "ThirdParty". Check whether you can find libscotch.so on your system, if so, the following link/discussion explains how to add it to your LD_LIBRARY_PATH: https://stackoverflow.com/questions/...-path-in-linux If it's not installed, build/compile it first: The scotchDecomp library can then be built in src/parallel/decompose/decompositionMethods/scotchDecomp Klaus |
June 9, 2021, 05:39 |
Rep Power: 16 |
Thanks a lot klausb for you kind help and suggestion. I will try and report in this post. Thanks again for your time.
June 13, 2021, 09:04 |
Rep Power: 16 |
Hello again Klausb,
I was trying to understand and follow you steps regarding the scotch decomposition method, I have some doubts, could you kindly help me with these: 1. How to find libscotch.so on my system? 2. How to build/compile the scotch from src/parallel/decompose/scotchDecomp? I could see there are 2 folders: Make and inInclude + 2 files--scotchDecomp.c and scotchDecomp.c Sorry for troubling you regarding these naive questions. Any further comment/suggestion will be very helpful. Thanks in advance. |
June 13, 2021, 10:22 |
Klaus
Rep Power: 22 |
1: Just use your file browser/explorer and search your OpenFOAM directory for the file as with any other file your're searching - nothing special.
2: Open a terminal, go to the directory where the source files an the Make directory are located and type: wmake libso For 2: You must have development tools installed on your system i.e. dependencies and a compiler. |
June 14, 2021, 07:29 |
Rep Power: 16 |
Many thanks Klausb for your prompt and helpful advice. I updated the Ubuntu version to the latest and then tried to install OF v 1906, finally managed to get the things working. Your post helped me a lot, thanks again for your kind suggestions/help.
June 6, 2022, 04:40 |
Nguyen Trong Hiep
Rep Power: 8 |
I have same problem in wsl with ubuntu 20.04 and OF 2112,
I have installed scoth and the LD_LIBRARY_PATH have libscotch.so Code:
echo $LD_LIBRARY_PATH /home/hiep/OpenFOAM/hiep-v2112/platforms/linux64GccDPInt32Opt/lib: /home/hiep/OpenFOAM-v2112/site/2112/platforms/linux64GccDPInt32Opt/lib: /home/hiep/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/sys-openmpi: /home/hiep/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib: /home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib/sys-openmpi: /home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib: /home/hiep/ThirdParty-v2112/platforms/linux64Gcc/fftw-3.3.10/lib: /home/hiep/ThirdParty-v2112/platforms/linux64Gcc/CGAL-4.14.3/lib64: /home/hiep/ThirdParty-v2112/platforms/linux64Gcc/boost_1_74_0/lib64: /usr/lib/x86_64-linux-gnu/openmpi/lib: /home/hiep/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/dummy: /usr/local/lib/ Code:
find -name libscotch.so ./home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib/libscotch.so ./home/hiep/ThirdParty-v2112/platforms/linux64GccDPInt32/lib/sys-openmpi/libscotch.so |
December 7, 2022, 03:13 |
Rep Power: 10 |
Hi, I recently ran into a problem myself when i tried to compile scotch 6.1.0 for openfoam 2206 on ubuntu jammy jelly. I'll post it here in case it can help someone or my future self.
To get to the point where i ran into the problem i followed the steps given by klausb above. First of all, I didn't really read the guide on the gitlab page of scotch really well so i missed the step where you had to make a symlinc from $WM_PROJECT_DIR/src/parallel/decompose/scotchDecomp/src/Makefile.inc to $WM_PROJECT_DIR/src/parallel/decompose/scotchDecomp/src/Make.inc/Makefile.inc.x86-64_pc_linux2 (The last part is dependent on your os). Doing this fixed the problem with missing windows.h during compilation, but exposed the next problem. The version of scotch that i downloaded from gitlab was configured to be compiled on windows, and so it used a version of pthread.h that was configured for windows. So i ran this to make sure i still had the original: sudo apt install libc6 libc6-dev Then: cd $WM_PROJECT_DIR/src/parallel/decompose/scotchDecomp/src/misc Next make a symlink from pthread in this folder to the one you just installed/reinstalled: ln -sf /usr/include/pthread.h ./pthread.h now I was finally able to run Allwmake from $WM_PROJECT_DIR/src/parallel/decompose . |
[OpenFOAM] Questions about Paraview to show Parallel run of OpenFOAM | padian | ParaView | 20 | September 24, 2018 12:52 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
Unable to run OpenFOAM 1.6-ext in parallel with more than one machine | mm.abdollahzadeh | OpenFOAM Installation | 14 | January 27, 2014 09:40 |
Parallel run of OpenFOAM in linux and windows side by side | m2montazari | OpenFOAM Running, Solving & CFD | 5 | June 24, 2011 03:26 |
