comfortHotRoom laminar carshes with negative temperature |
June 7, 2021, 07:19 |
Kai Salscheider
Rep Power: 8 |
Hello forum!
I want to simulate a gas atmosphere with laminar inlets, comparable to the comfortHotRoom tutorial in OF8. Upon changing the momentumTransport/simulationType from RAS to laminar in the tutorial case (and disabling the functionObjects, see attached case), the simulation crashes in time step 4 when solving for p_rgh with the error message "Negative initial temperature T0: -1046.27". The attached pictures show the comparison between the fields p, p_rgh, U and T of the standard tutorial case and the laminar one. As one can see, p is fairly similar, but p_rgh, T and U show no similarities with U being the big outlier with a velocity of over 200 m/s. T and p_rgh are at least in the same order of magnitude compared to the turbulent case. Question: Why is the case not running with laminar settings and what can I do make it run? Thanks in advance! p.png p_rgh.png T.png U.png comfortHotRoom_laminar.tar.gz |
June 7, 2021, 09:11 |
Tobias Holzmann
Rep Power: 52 |
Okay ... thanks for reporting. I will check it out as the development of the comfort library as well as the tutorial comes from my side. I will need a few days as I don´t have access to my laptop right now. For the velocity field something seems to be wired as you do have almost 200 m/s which is the source of the crash.
Keep foaming, Tobias Holzmann |
June 8, 2021, 18:59 |
Tobias Holzmann
Rep Power: 52 |
I checked the case and for any reason, we get some numerical problems during the first time-steps which let the case diverge. The turbulence model smooths the errors and hence, it is in a limit in which everything works fine. A possible solution for stabilization is to add a fvOptions file in the system folder and limit the velocity:
foamAnalyzerLimitU { type limitVelocity; active true; max 5; selectionMode all; } Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.01 0 0);
June 9, 2021, 04:44 |
Kai Salscheider
Rep Power: 8 |
Thank you Tobi for your enlightening answer!
Just a few thoughts: So the best way to solve this problem would be the calculation of the initial field with a transient simulation run for a few time steps? On the other hand, this should just help with convergence speed, as the steady state solution should be independent from the initial conditions, correct? Greetings Kai Last edited by Skaiwalker; June 10, 2021 at 03:37. Reason: Wording... |
June 9, 2021, 16:12 |
Tobias Holzmann
Rep Power: 52 |
Correct. You also can try to initialize the solution using the potentialFoam. However, in that case it is sufficient to initialize the velocity field (internal field) with a value different compared to (0 0 0).
June 10, 2021, 03:45 |
Kai Salscheider
Rep Power: 8 |
Thanks again Tobi!
I'll try out potentialFoam. Kudos to you for your friendly and precise answers! |
June 28, 2021, 13:49 |
initialization of p
Kai Salscheider
Rep Power: 8 |
Hello Tobi and others interested in this topic!
A thread of your's popped up on the thread list which suggests that, in standard OF createFields, the pressure field initialization is not optimal for buoyancy driven flows. The different initialization method is described in this post by Hannes. I've changed the solver accordingly and now the laminar problem doesn't explode anymore, albeit not converging either, as can be seen in the residuals graph. Smaller underrelaxation for p_rgh doesn't help either. Up until now I didn't have time for more testing and just wanted to let you know. residuals_comfortHotRoomLaminar.png Greetings Kai |
laminar flow, negative temperature |
Error: Negative initial temperature T0, supersonic flows: sonicFoam, rhoCentralFoam | OlliCFD | OpenFOAM Running, Solving & CFD | 10 | November 21, 2024 01:33 |
rhoCentralFoam Negative initial temperature in simulation of gas jet into vacuum | c_underwood | OpenFOAM Running, Solving & CFD | 1 | November 19, 2020 15:45 |
Laminar Non-premixed CH4-air combustion Temperature problem | SinNi | FLUENT | 7 | April 9, 2020 07:25 |
Negative temperature T0 in sonicFoam OF 5.x | deepbandivadekar | OpenFOAM Running, Solving & CFD | 8 | August 20, 2018 10:40 |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 18:35 |
