rhoCentralFoam - Supersonic nozzle BC's
Like Tree2Likes
  • 2 Post By shock77
Old   June 3, 2021, 13:36
Post rhoCentralFoam - Supersonic nozzle BC's
retroglass is on a distinguished road
Hello, I've been using OpenFOAM for a few months, so I am fairly new to most of the applications. I've been trying to simulate a supersonic nozzle at various altitudes to see the flow conditions inside the nozzle. Only have the divergent part where my inlet is the "throat" and the outlet is the nozzle outlet.
I've been meaning to ask a few questions regarding my system. Since I don't have a reservoir or a combustion chamber, is it safe to use a fixedValue for the pressure at the throat? (Where I calculated the appropriate values.) I ran it a few different back pressures but the exit results don't seem to get affected by it. What would be the reason?
I read some of the applications of pressureInletOutletVelocity. Would it be feasible for this simulation? Tried using it for the inlet (throat) with totalPressure, but got a negative initial temperature error.
I've added my p, T and U case files. Thank you all for your time.
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325.1; //101325
boundaryField
    front
        type            empty;
    back
        type            empty;
    inlet
    type        totalPressure; //totalPressure
    value        uniform 5134898;
    rho        rho;
    psi        thermo:psi;
    p0        uniform 5134898;
    gamma        1.4;
    field        p;
    nozzle
        type            zeroGradient;
    outlet
        type            waveTransmissive;
        gamma           1.4;
    field        p;
    phi        phi;
    rho        rho;
    psi        thermo:psi;
        fieldInf        101325;
          lInf            15;
        value           uniform 101325;
    symmetry
        type            symmetryPlane;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (100 0 0); // ()
boundaryField
    front
        type            empty;
    back
        type            empty;
    inlet
        type           fixedValue;
        value        uniform ( 1213 0 0 );
        //type        pressureInletOutletVelocity;
        //value        uniform ( 1213 0 0 );
    nozzle
        type           slip;
    outlet
       type        zeroGradient;
    symmetry
        type            symmetryPlane;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 274;
boundaryField
    front
        type            empty;
    back
        type            empty;
    inlet
        type           fixedValue; //totalTemperature
        value        uniform 2965;
        gamma        1.4;
        T0        uniform 2965;
        inletValue    uniform 2965;
        psi        thermo:psi;
        field        U;
    nozzle
        type            zeroGradient;
    outlet
        type            zeroGradient;
    symmetry
        type            symmetryPlane;
retroglass is offline   Reply With Quote
Old   June 4, 2021, 06:42
shock77 is on a distinguished road
I would mesh the entire nozzle (convergent and divergent part). For the inlet I would choose totalPressure, totalTemperature, pressureInletOutletVelocity. I suppose in your case slip walls should be ok. At the outlet waveTransmissive for p and U and zeroGradient for T.
A 2D-Mesh is not applicable for a nozzle. I hope you mean axially symmetrical mesh, basically a wedge.
hogsonik and retroglass like this.
shock77 is offline   Reply With Quote
Old   June 4, 2021, 12:10
Hi shock,
Yes, I totally forgot to mention that. It is a 2D axis-symmetric mesh.
I used method of characteristics for the divergent part of course, but I don't think there is such an ideal approach for the congervent part right? I remember someone mentioning like basic rule of thumbs would be enough mostly.
waveTransmissive outlet for the velocity gave me more stable results. Thanks for that! And using fixedValue for the pressure at the throat is what's making the exit pressure constant at all back pressures I implemented. (totalPressure at the throat doesn't make much sense I think?)
Using totalPressure with a convergent part is more feasible as you suggested. I'll give that a try.
Thank you so much.
Old   June 7, 2021, 05:00
I am glad your results improved!
Using fixedPressure at the throat can be very tricky, thats why I suggested to model the convergent and divergent part of the nozzle and to use totalPressure. The reason is the following:
Imagine a long throttle, lets say 100 mm long. What you learn is that the throttle becomes critical, but thats in fact not entirely true. For like 90% of the throttle you will have Ma: 0.8-0.9, only at the exit of throat you will have Ma = 1.
Old   June 8, 2021, 08:42
Yes, now I understand why some method of characteristics papers said about how the mach distribution around the throat should be circular. (As opposed to being like a vertical cut.)
With totalPressure and totalTemperature I got some good results. But I noticed that if I dont give a slight initial velocity for the internalField the case just diverges to unreal velocities like 10^38 m/s. Do you have any idea why that happens?
Thanks again!
retro.
Old   June 8, 2021, 17:33
Lewis
cfdcheckers is on a distinguished road
Would these same BCs work for a compressible but subsonic flow? I am trying to work out one such case using rhoSimpleFoam but my solver crashes.
cfdcheckers is offline   Reply With Quote
Old   June 9, 2021, 04:37
Yes, you can also use the totalPressure BC for subsonic flows, but the formulation of the total pressure changes, see here: https://cpp.openfoam.org/v3/a02627.html
And also there is no need to use waveTransmissive, since you do not have anny shockwaves. As far as I know you use totalPressure and fixedPressure for inlet and outlet in subsonic flows.
Old   June 9, 2021, 05:39
Domenico Lahaye
dlahaye is on a distinguished road
My doubt here is whether in the regime in which 0.4 <= Mach-number <= 1 pressure waves might arise that will reflect from the outlet patch and cause spurious effects.
Any ideas?
dlahaye is offline   Reply With Quote
Old   June 9, 2021, 10:45
Lewis
Yup, I think it's a good pointer and that should be fine. I am however stuck with the corresponding T and U BCs for inlet and outlet. I tried setting mass flow rate for U with those pressure BCs but it doesn't quiet work - probably because of bad T BCs.
Old   June 10, 2021, 06:22
Originally Posted by retroglass View Post
Thanks again!
retro.
Sometime when I start with 0 m/s I get strange oscillations. There is a reason, but I have actually forgotten way. I dont think its the checker board problem, but also in my cases it helps to start with like 1 m/s.
Old   April 5, 2024, 13:24
Exclamation Problems with simulation control
  #11
ok2ood is on a distinguished road
Hi there,
I am also simulating a CD nozzle with rhoCentralFoam but I am having trouble with actually getting the simulation ready, as I get many errors:
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam"
#5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam"
I've seen that changing deltaT and other controlDict parameters it actually simulates for a few iterations but again stops, but then all the residuals and everything is 0, so I don't think it is actually simulating.
May I get some help on this topic please.
Many thanks in advance.
ok2ood is offline   Reply With Quote
nozzle flow, openfoam, rhocentralfoam
Help: rhoCentralFoam de Laval Nozzle supersonic shock waves vizvaz OpenFOAM Running, Solving & CFD 2 August 15, 2022 09:27
kOmegaSST Boundary Conditions for Supersonic Nozzle shang2 OpenFOAM Running, Solving & CFD 2 September 17, 2018 14:06
Supersonic Nozzle Exhaust Simulation mikeh FLUENT 0 May 1, 2014 22:28
calculate a nozzle flow using rhoCentralFoam hg2lf OpenFOAM 0 October 25, 2012 22:26
some questions for supersonic channel nozzle goldenland FLUENT 2 November 4, 2007 22:18
