PatchField Entry error
Like Tree1Likes
  • 1 Post By CHUMMAR
Old   May 28, 2021, 04:16
Question PatchField Entry error
Amal Chummar
CHUMMAR is on a distinguished road
I am very new to OpenFoam and am trying to use chtmultiregionfoam to validate a conjugate numerical problem. I have been able to successfully run blockMesh, topoSet and splitMeshRegions -cellZones -overwrite. but as soon as i type in chtMultiRegionFoam to try and run the problem I face this error which is "cannot find patchField entry for frontAndBack"
BlockMeshDict :-
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object blockMeshDict;
convertToMeters 0.001;
vertices
(-0.2 0 0)
(1 0 0)
(1 1 0)
(-0.2 1 0)
(-0.2 0 1)
(1 0 1)
(1 1 1)
(-0.2 1 1)
blocks
hex (0 1 2 3 4 5 6 7) fluid (20 20 10) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(4 0 3 7)
outlet
type patch;
faces
(5 1 2 6)
frontAndBack
type wall;
faces
(0 1 2 3)
(4 5 6 7)
topAndBottom
type wall;
faces
(0 1 5 4)
(3 2 6 7)
mergePatchPairs
topoSetDict :-
actions
name c0;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (-0.2 0 0) (0 1 1);
name solid;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo
{ set c0; }
name c1;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (0 0 0) (1 1 1);
name fluid;
type cellZoneSet;
action new;
sourceInfo
{ set c1; }
ERROR :-
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region solid for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for frontAndBack
file: /home/chummarvm/OpenFOAM-dev/tutorials/heatTransfer/chtMultiRegionFoam/newtest/0/fluid/U.boundaryField from line 27 to line 32.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 188.
FOAM exiting
CHUMMAR is offline   Reply With Quote
Old   May 28, 2021, 04:40
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Amal,
The solver cannot find the boundary condition for "frontAndBack" for U in the "fluid" region.
Do you have a boundary condition defined for this patch?
Can you post your U file for the "fluid" region? (0/fluid/U)
Yann
Yann is offline   Reply With Quote
Old   May 28, 2021, 04:53
Post 0/fluid/u
Amal Chummar
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0/fluid";
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform (0 0 0);
boundaryField
outlet
type pressureInletOutletVelocity;
value $internalField;
fluid_to_solid
type noSlip;
I am trying to solve a buoyancy driven flow related heat transfer problem and so kept the T file as the main one describing all boundaries.
dimensions [ 0 0 0 1 0 0 0 ];
internalField uniform 300;
boundaryField
outlet
type inletOutlet;
inletValue $internalField;
frontAndBack
type zeroGradient;
topAndBottom
type zeroGradient;
fluid_to_solid
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappaMethod fluidThermo;
Since I am very new to OpenFOAM pls forgive me for any silly errors.
Old   May 28, 2021, 05:02
Yann
For every variable, you need to define a boundary condition on each patch in your domain.
This is what the solver complains about in your initial post.
Cheers,
Yann
Old   June 1, 2021, 01:50
Talking Got it running without errors!
Amal Chummar
Thanks Yann, that was the problem
Yann likes this.
Old   June 5, 2021, 02:44
Default chtMultiRegionFoam error running
Ludovico
rideste is on a distinguished road
I'm new in OpenFoam; i'm trying to simulate an heatexchanger tube in tube counter-current air-co2 with a strate of alluminium interposed. I use chtMultiRegionFoam with wall function for y+>30. But when run the simulation at the time=1 there are negative Temperature, so at time=2 give me an error.
I try with fvOptions limiter, but the calculus are very pertub with limiters and diverge.
Someone can help me?
rideste is offline   Reply With Quote
Old   June 8, 2021, 05:04
Yann
Can you share more about you case setup, especially the boundary conditions you are using?
The log shows big continuity error so my first thought would be that something could be wrong about the boundary conditions.
Yann
Old   June 8, 2021, 06:15
Ludovico
used low-Re funcition, mesh wit y+<2.
I try to share file 0/air.
file of co2 is analogus, while in file of alluminium there is p,T with mixedcoupledbaff..... function.
I can't upload files U,alphat,nut.
alphat is all calculated.
nut is all calcultated with lowRe wallFunction.
U fixedvalue inlet, zeroGradient outlet and noSlip on walls.
Old   June 8, 2021, 06:25
Ludovico
how i can upload openfoam files?
chtmultiregionfoam
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
