To use wall functions or not? y+ = 1 with Spalart Allmaras |
May 22, 2021, 10:27 |
Hello there,
I have always used Fluent for CFD simulations but I'm required now to use OpenFoam. I want to run a simple simulation of an aircraft with a speed of 40m/s. I chose the simpleFoam module with Spalart Allmaras as turbulence model (it's required for the project). Also I will mesh as such the y+ is around 1-2 . So I'm solving the Viscous Sublayer if I understand correctly. What I'm asking is in the above case, I don't need any wall treatment...right? and if not then do I need to specify that in OpenFoam? Right now my nut file in the 0 folder specifies type nutUSpaldingWallfunction; and value uniform 0; There is also a file nuTilda which specifies type zeroGradient; Is this correct? Thank you in advance. |
May 25, 2021, 18:51 |
Klaus
Rep Power: 22 |
Have a look at the .../OpenFOAM-8/tutorials/incompressible/simpleFoam/airFoil2D tutorial
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
How are Wall Functions Practically Implemented! | pche8701 | Main CFD Forum | 2 | June 2, 2016 10:58 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
wall functions implementation | besh | OpenFOAM Programming & Development | 0 | January 1, 2013 09:14 |
