pimpleFoam imposible to run while simple no problem |
May 20, 2021, 15:27 |
Franco
Rep Power: 7 |
I am seeking help in a strange behavior that I have no clue where to go. I have a case with a complex geometry, and cyclicAMI and symmetry boundaries (it is a quarter of cylinder where the InletAMI and OutletAMI are connected by cyclicAMI and sym_1 and sym_2 are symmetry planes). I create my volume mesh using snappyHexMesh and after create the symmetry and cyclicAMI patches with createPatch up to here everything okey. my issue comes here: if I run simpleFoam it runs correctly until it converges to 1-5 residuals for p and U. but if I run pimpleFoam the solver explodes with the typical error divided by zero where there is not much indication about the problem. it crashes after 3 or 4 iteration whatever the deltaT is (it is not a Co number problem as it crashes even with values down to maxCo 0.02) and I dont know where to go from here as the fvSolution and fvSchemes seems okey, even if I use the results from a converged simpleFoam and from there I run pimple, it will crash after 3 or 4 iterations (in time) I am attaching the fvSolutions and fvSchemes and also the link for the case as it can be difficult to have an idea with my description of the problem (but I not sure what can I said more than these... as the error does not give any clear information.) small note, in the case i put a mesh that is quiet coarse, but the problem is still there even at finer meshes. link for complete case: https://drive.google.com/file/d/1EYO...ew?usp=sharing fvSchemes_1.txt fvSolution.txt any help or point in direction will be appreciated |
May 20, 2021, 16:15 |
Herpes Free Engineer
Rep Power: 13 |
Please remove the 'bounded' keywords for any transient simulation.
Hope this helps.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 20, 2021, 16:27 |
#3 | |
Franco
Rep Power: 7 |
even when it is running in steadyState mode? see fvSchemes I am going to try of course, only asking to learn a little bit more best regards |
May 20, 2021, 17:07 |
Rep Power: 13 |
Hi
No no, please keep the "bounded" keyword for steady-state simulations. But remove it when you run transient simulations. This keyword is useful for steady cases, but destabilises transient cases (to my experience).
May 20, 2021, 17:31 |
#5 | |
Franco
Rep Power: 7 |
log.pimpleFoam.txt |
May 20, 2021, 17:44 |
Rep Power: 13 |
I had been writing items - and everything was vanished... This forum is really low quality...
Anyways, some ideas: fvSchemes: - I assume you don't use steadyState for the ddtSchemes. If so, please change it to Euler. - please use a limiter (e.g. cellMDLimited) in gradSchemes - and preferably - don't use it a default value there - if things keep blowing up - use the most diffusive schemes in fvSchemes - you can search them, e.g. upwind for divergence - check AMI settings - there was a limiter that can be applied to AMI to avoid zero-face issues - please search it (I must sleep - otherwise will post tomorrow) AMIWeights FO fvSolution: - relaxationfactor for p from 0.5 to 0.3 - relTol for pFinal from 0.01 to 0 - use the same smoother for the p solver - nOuterCorrectors from 1 to 3 EDIT: could you please also add fieldMinMax FO to monitor min max p, U as well?
May 21, 2021, 17:12 |
2 cents
Paulin FERRO
Rep Power: 5 |
I agree with HPE. you have no limiter on your schemes. This is very unlikely to obtain a non oscillating or stable solution with Gauss linear for div(phi,U). Instead : linearUpwindV grad(U) and add a limiter on grad(U) or limitedLinearV 1 or vanLeerV. Go to upwind for turbulence. Eventually add a stronger limitation on non ortho correction : limited 0.7 instead of corrected. For relaxation factor because you are want to use pimpleFoam I assume you want to get a transient result. The relaxation factors for the last PIMPLE iteration must be 1. Good luck Paulin |
May 22, 2021, 09:34 |
#8 | ||
Franco
Rep Power: 7 |
Hello guys,
wow so much to learn, it is difficult to even follow you! eheheh, I should learn more about the schemes for the different terms. Quote:
well I was trying to use the pimple algorithm in steady state mode. thats why I was using the - check AMI settings - there was a limiter that can be applied to AMI to avoid zero-face issues - please search it (I must sleep - otherwise will post tomorrow) AMIWeights FO I did not understood your comment about these, and I am quiet interesting in this issue, as when I go in higher refimments (lower cell sizes) I am finishing with 0 weighed AMIs and then the simulation explodes.... I understand that this is comming from a face that does nothing that overlaps in the other patch. but what I dont get is as the refiment gets better the cyclicAMI should too (as the geometry is better represented) the function that you sendme weightsAMI if I understood correctly it only help to visualize the weights in the patches but nothing else. do you know any particular way of getting better weights? the geometry I can not changed.... for the rest of the things I am going to integrate them to the fvSchemes and fvSolutions when I go back to work as I do not have acces right now, but I promis I will have a look. so much to learn thanks guys! |
May 23, 2021, 15:45 |
#9 | |
Rep Power: 13 |
pimplefoam, simplevspimple |
Simple specie diffusion problem with Fundamental solution of Laplace Equation | mohibanwar | ANSYS | 0 | September 20, 2020 23:58 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
damBreak case parallel run problem | behzad-cfd | OpenFOAM Running, Solving & CFD | 5 | August 2, 2015 18:18 |
Simple Meshing Problem with Gambit | Mario | FLUENT | 4 | April 18, 2003 10:52 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 10:11 |
