crazy problem with #calc and blockMeshDict
Like Tree2Likes
  • 2 Post By HPE
Old   May 15, 2021, 16:06
Default crazy problem with #calc and blockMeshDict
Alan w
boffin5 is on a distinguished road
Initially I had a problem with getting #calc to work in a blockMeshDict file. But with suggestions from this forum regarding sudo apt-get updates, I got it to work.
But then, I copied blockMeshDict to a run directory for a different simulation, and it fails again:
"creating block mesh from "system/blockMeshDict" using #calcEntry at line 31 in file "....blockMeshDict" --> FOAM FATAL ERROR
(line 31 is the one with lx #calc, below)
The same Dict file works in one run directory, but not in another one!
This is truly perplexing! I even ran the updates in the new directory, but it didn't help. Any ideas as to this inconsistency?
Here are the lines in blockMeshDict in question:
xmin -3;
xmax 5;
ymin -2;
ymax 2;
zmin 0;
zmax 2;
deltax 0.1; //cell size in meters
deltay 0.1;
deltaz 0.1;
lx #calc "($xmax) - ($xmin)";
ly #calc "($ymax) - ($ymin)";
lz #calc "($zmax) - ($zmin)";
xcells #calc "round($lx)/($deltax)";
ycells #calc "round($ly)/($deltay)";
zcells #calc "round($lz)/($deltaz)";
Thanks in advance, Alan
table {mso-displayed-decimal-separator:"\."; mso-displayed-thousand-separator:"\,";}tr {mso-height-source:auto;}col {mso-width-source:auto;}br {mso-data-placement:same-cell;}td {padding-top:1px; padding-right:1px; padding-left:1px; mso-ignoreadding; color:black; font-size:12.0pt; font-weight:400; font-style:normal; text-decoration:none; font-family:Calibri, sans-serif; mso-font-charset:0; mso-number-format:General; text-align:general; vertical-align:bottom; border:none; mso-background-source:auto; mso-pattern:auto; mso-protection:locked visible; white-space:nowrap; mso-rotate:0;}.xl65 {font-weight:700;}.xl66 {color:#0563C1; text-decoration:underline; text-underline-style:single;}
boffin5 is offline   Reply With Quote
Old   May 15, 2021, 16:12
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Please completely abandon "#calc" and start using "#eval" directive (link) which is faster, cleaner and stable.
I don't see any lexical or semantic problem in the #calcs.
May be the actual problem is that #calc could not be compiled due to some sudo rights, because the error message indicates the first #calc? If that's the case just use #eval since it does not need any compilation (or if you insist on #calc, please ensure that you have proper file rights allowing compilations).
Hope this helps a bit.
HPE is offline   Reply With Quote
Old   July 14, 2023, 08:00
Voulet is on a distinguished road
Hi.
In case it may help future generations : I had the following error while using #calc :
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_88c28f6ea7aee10af5a41c01cc48ce917ab7d4a3/platforms/linux64GccDPInt32Opt/lib/libcodeStream_88c28f6ea7aee10af5a41c01cc48ce917ab7d4a3.so"
file: /home/user/testOF/testNewSolver/test1:1/system/blockMeshDict from line 17 to line 17.
    From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 211.
And it was because the name of my case folder contain "regular like expressions" as it was named test1:1.
I've just named it more normally and it now works.
« Debugging is what CFD is about. 5 minutes to modify your code, 5 months to find why it does not work anymore. »
Voulet is offline   Reply With Quote
Mass flow rate issue parthigcar OpenFOAM Running, Solving & CFD 2 April 12, 2021 12:03
Simulation of a small element of a Hydrodynamic Journal Bearing in Wind Energy Appln Anuraag OpenFOAM 0 February 24, 2021 10:03
[BlockMesh] Problem with blockMesh internal faces parthigcar Main CFD Forum 0 January 20, 2021 07:10
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict foadsf OpenFOAM Meshing & Mesh Conversion 9 August 23, 2018 08:54
[blockMesh] blockMesh with parametric mesh. Unusual and unseen problem 13msmemusman OpenFOAM Meshing & Mesh Conversion 1 June 13, 2016 03:25
