solids4foam FSI overset parallel run problem
Like Tree1Likes
  • 1 Post By bigphil
Old   May 15, 2021, 08:33
Default solids4foam FSI overset parallel run problem
Emre Cenk Ersan
jenksson is on a distinguished road
Hello everyone,
I could not solve the solids4foam FSI overset tutorial (beaminCrossFlow) in parallel. I'm getting mpi segmentation fault right after the initialization of the newSubsetMotionSolverFvMesh (tried simple, scotch and metis decomposition methods). It works in serial without problem.
Does anybody have some experience or any information regarding this issue?
Thank you for any help.
Cenk.
jenksson is offline   Reply With Quote
Old   July 28, 2021, 19:27
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Cenk,
As you noted, this is also discussed here: Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend".
I have just added a new issue to the solids4foam repository issues page so that it doesn't get forgotten: https://bitbucket.org/philip_cardiff...do-not-work-in
If it works in the fluid-only cases then it should be possible to get it to work.
Philip
Tianyz likes this.
bigphil is offline   Reply With Quote
Old   October 17, 2022, 16:27
Thumbs up Solids4Foam Parallel issue
Manchester
Tianyz is on a distinguished road
Originally Posted by bigphil View Post
Hi Cenk,
Philip
Hi, Philip.
Many thanks for your contribution to this open-source package for FSI, which makes my work much easier. I'm now doing a FSI simulation with solids4Foam, but got some problem.
My case is turbulent flow around long vertical flexible riser, with deformable overset mesh. To accormadate deformation of solid part, newSubsetMotionSolverFvMesh is imployed according to the tutorial case flexible beam (overset version).
But as you found, this method doesn't work well in parallel, which will take much more time to run if in serial, since the huge number of cells of my case.
So, I'm wondering is there any other avaliable model to replace this newSubsetMotionSolverFvMesh? Or can we try to fix it?
Thank you again for work!
Best,
Tian
Tianyz is offline   Reply With Quote
problem "face 0 area does not match neighbour by xxx%" in parallel run Aleigus OpenFOAM 0 July 2, 2017 13:10
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 12:05
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 11:25
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Problem with parallel run Antoniorp OpenFOAM Running, Solving & CFD 0 March 30, 2015 09:15
