Coded boundary condition
Like Tree2Likes
  • 2 Post By Tobermory
Old   May 9, 2021, 12:07
Default Coded boundary condition
subhojitkadiacfd is on a distinguished road
Hi all,
How can I introduce a boundary condition of a variable as a function of another variable. Lets say, how can I introduce the following boundary condition:
epsilon=0.391*k*y*z
Thanking you.
Subhojit
subhojitkadiacfd is offline   Reply With Quote
Old   May 10, 2021, 09:26
Tobermory will become famous soon enough
Simplest would be to use the funkSetBoundaryField utility, but you want to do it with codeStream, so here's how. Use a fixedValue type for the epsilon boundary patch you are interested in (here I will assume that this patch is called "inlet"), and put this for the value:
inlet
   type    fixedValue;
   value   #codeStream {
               codeInclude #{ #include "fvCFD.H" #};
               codeOptions  #{ -I$(LIB_SRC)/finiteVolume/lnInclude -I$(LIB_SRC)/meshTools/lnInclude #};
               codeLibs #{ -lfiniteVolume -lmeshTools #};
               code #{
                  const IOdictionary& d = static_cast<const IOdictionary&>(dict.parent().parent());
                  const fvMesh& mesh = refCast<const fvMesh>(d.db());
                  const label id = mesh.boundary().findPatchID("inlet");
                  const fvPatch& patch = mesh.boundary()[id];
                  scalarField epsp(patch.size(), 0.0);
                  const volScalarField& k = mesh.lookupObject<volScalarField>("k");
                  const scalarField& kp = k.boundaryField()[id];
                  forAll(epsp, facei)
                     const scalar y = patch.Cf()[facei].y();
                     epsp[facei] = 0.391*kp[facei]*y;
                  writeEntry(os, "", epsp);
Note the footwork that's required to find the patch, and to get references to the mesh and other fields. Good luck!
Tobermory is offline   Reply With Quote
Old   May 12, 2021, 06:42
Many thanks. It shows dict is not defined. How to remove it?
codedfixed, codedmixed
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
