add a force in momentum equation
Like Tree4Likes
  • 1 Post By pferro
  • 2 Post By pferro
  • 1 Post By Mahmoud Abbaszadeh
Old   May 6, 2021, 21:11
Default add a force in momentum equation
simona
carolee is on a distinguished road
Hi everybody,
I am new to openfoam, I am studying a laminar flow of water in a cylindrical tube with velocity 1m / s using simpleFoam and I need to add a source term in the momentum equation which is a force in the same direction of flow which should increase the velocity of the fluid flow a little bit, I tried with this method but the velocity remains at the same value and the flow becomes non-laminar, please who can help me to solve this problem
dimensionedVector F("F", dimensionSet(0,1,-2,0,0,0,0), vector(0,0,30));
tmp<fvVectorMatrix> tUEqn
fvm::div(phi, U)
+ MRF.DDt(U)
+ turbulence->divDevReff(U)
- fvm::laplacian(mu, U)
fvOptions(U)
+ F
fvVectorMatrix& UEqn = tUEqn.ref();
carolee is offline   Reply With Quote
Old   May 7, 2021, 07:42
simona
any reply will be appreciated, I really want help
Old   May 7, 2021, 07:54
Hojatollah Gholami
Hgholami is on a distinguished road
Hello
may you can use temple of bodyForce() in fsi of foam-extend4.0 (unsTotalLagrangianSolid.C).
bodyForce() = dimensionedVector(solidProperties().lookup("g"));
fvVectorMatrix DEqn
rho_*fvm::d2dt2(D_)
== fvm::laplacian(2*muf_ + lambdaf_, D_, "laplacian(DD,D)")
+ fvc::div
mesh().Sf()
- (muf_ + lambdaf_)*gradDf_
+ muf_*gradDf_.T()
+ lambdaf_*(I*tr(gradDf_))
+ rho_*bodyForce()
Hgholami is offline   Reply With Quote
Old   May 7, 2021, 12:48
simona
thank you gholami for your reply
Old   May 15, 2021, 15:31
Default a bit of help
Paulin FERRO
pferro is on a distinguished road
For instance you can :
1 : declare a volVectorField mySource.
2 : loop over the cells and fill mySource. Here you can loop on a specific zone of your mesh.
3 : add in the left member of Ueqn the source mySource.
Good luck !
carolee likes this.
pferro is offline   Reply With Quote
Old   May 17, 2021, 05:09
Default solution
Paulin FERRO
Please find below some details of a possible implementation. Note that I didn't have tested the code since I am directly writing it here. Also note that there are other ways for doing it.
I assume that we use an incompressible solver such as simpleFoam or pimpleFoam. In this case each member of the momentum equation is divided by rho. As rho is uniform the solver use the kinematic viscosity and a modified pressure : [p/rho] = m^2 / s^2.
The source term in the momentum equation has the dimension of an acceleration i.e = m/s^2.
First step : creating the momentum source
In createField.H of the solver we declare a volVectorField and we call it force.
volVectorField force
IOobject
"force",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedVector("0", dimVelocity/dimTime, Zero)
On the code above we use
AUTO_WRITE
this will be useful for visualizing the field in paraview.
Second step : filing the momentum source
The force volVectorField is initialized in createField.H and is equal to 0 on the whole mesh. Now we need to fill it according to what we want to do. Thus we need to create a loop over cells. For example we can do that in the UEqn.H file. This means that the source will be updated for each SIMPLE loop.
forAll(mesh.cells(),cellI)
// here do whatever you want to do
// for example we calculate force only if x > 0.5
// you can obtain cell center coordinates
const vector& cCenterCoor = mesh.C()[cellI];
// and create a test on the cell position
scalar xMax = 0.5 ;
if ( (pos(cCenterCoor[0] - xMax) )
force[cellI] = vector(1.,-1.,0.05); // again it's an example
else
force[cellI] = vector(0.,0.,0.); // if the condition above is not valid then the source remains zero
Third step : adding the source in Ueqn
Very simple :
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi,U)
- force
fvOptions(U)
Final step : compile
wmake
Good luck !
Paulin
oumnion and mllokloks like this.
Old   June 20, 2022, 09:14
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
On the code above we use this will be useful for visualizing the field in paraview.
Very simple :
Good luck !
Paulin
Hi Paulin,
I am wondering why you have not used fvOptions to introduce the body force into your equations?
Haitham Osman CFD likes this.
Mahmoud Abbaszadeh is offline   Reply With Quote
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Can not add force to Equn in interFoam,Help zhibin.wang OpenFOAM Running, Solving & CFD 0 August 22, 2016 08:10
how to add source-term in momentum equation for interFoam? anon_g OpenFOAM 9 October 18, 2011 13:47
how to add a force in the momentum equation guillaumem OpenFOAM 0 June 14, 2010 04:49
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 15:01
