pipe flow with rhoPimpleFoam pressure reflective problem |
May 3, 2021, 01:01 |
I solve the problem of air flow in a pipe with the rhopimpleFoam, and i found that the pressure will reflective from the outlet boundary condition back and forth.
I want to know how to resolve this problem. i have tried use trasimissive bc, it still cann't resolve this. the inlet velocity is 5m/s, and the channle is 20cmby20cm with 2m long. |
May 3, 2021, 03:29 |
Rep Power: 7 |
More informations are needed to be able to help, like boundary conditions or an image of your problem. What fluid is in the pipe? 20 m/s sounds like no density based solver is needed.
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
SimpleFoam Laminar Pipe Flow Pressure Drop Error | xiaolong | OpenFOAM Running, Solving & CFD | 3 | September 16, 2019 10:37 |
pressure gradient of a 2D periodic flow problem | Honey | FLUENT | 0 | September 19, 2012 03:21 |
Flow not moving - Supersonic/Initial Pressure problem? | shankara.2 | FLUENT | 0 | June 9, 2009 20:49 |
