April 28, 2021, 07:14 |
reactingParcelFoam equations
Rep Power: 9 |
What equations exactly solves reactingParcelFoam if I simulate compressible fluid with solid particles with temperature? No radiation, no chemical reactions, no combustion. Where I could find them?
I understand that it is compressible RANS equations with temperature field but I would like to see where they come from, papers or some other sources. |
May 13, 2021, 16:28 |
Rep Power: 9 |
May 15, 2021, 16:30 |
Herpes Free Engineer
Rep Power: 13 |
I think you might need to dig in the source code, I'm afraid.
These files could be a start: KinematicParcel.H/C (link) KinematicCloud.H/C ThermalParcel.H/C ThermalCloud.H/C These are the files that reactingParcelFoam uses to compute the Lagrangian fields if no reaction is considered. Trace calc* functions thereat. Hope helps.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 25, 2021, 10:35 |
Mohamed Zayed
Rep Power: 6 |
from the solver equation files, I extrapolated these functions. I hope it helps. Also the following paper "Modifying coalChemistryFoam for dense gas-solid simulation" by "Jingyuan Zhang" presents the coalChemistryFoam solver equations and it is pretty close to reactingParcelFoam. |
Solving coupled scalar transport equations in openFoam | pavaninguva | OpenFOAM Running, Solving & CFD | 1 | December 28, 2019 09:28 |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 15:52 |
Question about governing equations | newmancfd | OpenFOAM | 0 | May 15, 2013 11:41 |
Riemann invariants of adjoint equations of shallow water equations | zqb0929 | Main CFD Forum | 0 | March 15, 2012 01:54 |
? fluctuating equations for homogenous shear turb. | ff_fan | Main CFD Forum | 1 | September 20, 2002 08:39 |
