rhopimplefoam vs buoyantpimplefoam for heat transfer in open channel |
April 24, 2021, 14:54 |
Sameed Akber
Rep Power: 5 |
Hi all. I'm simulating heat transfer for an open channel flow over multiple cylindrical bodies. All thermophysical properties are constant. Water enters inlet at 38 C. Initial temperature is 22C so there is some temp gradient in the domain. There is a zero gradient temperature BC on side walls (including cylinder walls).
I'm a bit confused about which of the two solvers should be used in this case. Since I'm taking density to be constant, there should be no buoyant forces. However, I'm getting different results from the two solvers. I've also included temperature profiles over time in close vicinity of one of the cylinder which shows this difference. I would appreciate any help. |
buoyancy driven flow, buoyantpimplefoam, heat transfair, pimple transient, rhopimplefoam |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
