Mass flow rate issue
Like Tree1Likes
  • 1 Post By parthigcar
Old   April 12, 2021, 01:51
Post Mass flow rate issue
parth
parthigcar is on a distinguished road
I am trying to solve flow inside an inverted L type of annulus cylinder. I am simulating for one sector of the annulus cylinder. Where there is fixed pressure is provided at the inlet. The outlet is inletOutlet boundary condition. I have set up the case according to the TJunction case, which is also pressure based flow. The inlet pressure is about ~0.21 MPa. And my working material is sodium. I have divided the inlet pressure with the sodium density, and appropriate viscosity has been provided. However, I am not getting the correct mass flow rate at the outlet compared to lumped calculations. Additionally, I took the same geometry and ran the case in fluent, I got the correct mass flow at the outlet. I am not able to figure out where I have made mistake in the OpenFOAM model.
My boundary conditions are as follows:
Velocity boundary conditions
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    walls
        type            noSlip;
    wedge1
        type            symmetry;
    wedge2
        type            symmetry;
    top_walls
        type            noSlip;
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    interface3
        type            empty;
    interface4
        type            empty;
Pressure boundary conditions
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 238;
    walls
        type            zeroGradient;
    wedge1
        type            symmetry;
    wedge2
        type            symmetry;
    top_walls
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    interface3
        type            empty;
    interface4
        type            empty;
k
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
internalField   uniform 0.0034;
boundaryField
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.05;
        value           uniform 0.0034;
    walls
        type            kqRWallFunction;
    wedge1
        type            symmetry;
    wedge2
        type            symmetry;
    top_walls
    outlet
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    interface3
        type            empty;
    interface4
        type            empty;
omega
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 0.1;
boundaryField
    inlet
        type            turbulentMixingLengthFrequencyInlet;
        mixingLength    1.2;
        phi             phi;
        k               k;
        value           uniform 0.1;
    walls
        type            omegaWallFunction;
        blended         1;
        beta1           0.075;
        value           uniform 0.1;
    wedge1
        type            symmetry;
    wedge2
        type            symmetry;
    top_walls
        blended         1;
        beta1           0.075;
        value           uniform 0.1;
    outlet
        type            inletOutlet;
        inletValue      uniform 0.1;
        value           uniform 0.1;
    interface3
        type            empty;
    interface4
        type            empty;
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    walls
        type            nutkWallFunction;
        value           uniform 0;
    wedge1
        type            symmetry;
    wedge2
        type            symmetry;
    top_walls
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    interface3
        type            empty;
    interface4
        type            empty;
blockMesh
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale 1;
rin  0.28;
rout 0.29;
h0 0;
h1 1.8;
delh 0.0005;
sin30 0.5;
cos30 0.8660254037844387;
cos0 1;
sin0 0;
dr1 $rout - $rin;
dr2 0.06;
  //  (#calc "$rin*$cos30" #calc "$rin*-$sin30" $h0) //0
  //  (#calc "$rout*$cos30" #calc "$rout*-$sin30" $h0) //1
  //  (#calc "$rout*$cos30" #calc "$rout*$sin30" $h0) //2
  //  (#calc "$rin*$cos30" #calc "$rin*$sin30" $h0) //3
vertices
    (#calc "$rin*$cos30" #calc "$rin*-$sin30" $h1) //4
    (#calc "$rout*$cos30" #calc "$rout*-$sin30" $h1) //5
    (#calc "$rout*$cos30" #calc "$rout*$sin30" $h1) //6
    (#calc "$rin*$cos30" #calc "$rin*$sin30" $h1) //7
    (#calc "$rin*$cos30" #calc "$rin*-$sin30" $h1) //8
    (#calc "$rout*$cos30" #calc "$rout*-$sin30" $h1) //9
    (#calc "$rout*$cos30" #calc "$rout*$sin30" $h1) //10
    (#calc "$rin*$cos30" #calc "$rin*$sin30" $h1) //11
    (#calc "$rin*$cos30" #calc "$rin*-$sin30" #calc "$h1+$delh") //12
    (#calc "$rout*$cos30" #calc "$rout*-$sin30" #calc "$h1+$delh") //13
    (#calc "$rout*$cos30" #calc "$rout*$sin30" #calc "$h1+$delh") //14
    (#calc "$rin*$cos30" #calc "$rin*$sin30" #calc "$h1+$delh") //15
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*-$sin30" $h1) //16
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*-$sin30" $h1) //17
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*$sin30" $h1) //18
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*$sin30" $h1) //19
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*-$sin30" #calc "$h1+$delh") //20
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*-$sin30" #calc "$h1+$delh") //21
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*$sin30" #calc "$h1+$delh") //22
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*$sin30" #calc "$h1+$delh") //23
blocks
// block 1 and 2, x and y direction divisions should be same
// block 2 and 3 z, y direction divisions should be same
// block 1
hex (0 1 2 3 4 5 6 7) (  10    200    450)  simpleGrading (1 1 1)   // bird
// block 2
hex (8 9 10 11 12 13 14 15) (  10    200    15)  simpleGrading (1 1 1)   //head
// block 3
hex (16 17 18 19 20 21 22 23) (  40    200    15)  simpleGrading (1 1 1)    //beak
edges
  arc 0 3 ($rin 0 $h0)
  arc 1 2 ($rout 0 $h0)
  arc 4 7 ($rin 0 $h1)
  arc 5 6 ($rout 0 $h1)
  arc 8 11 ($rin 0 #calc "$h1")
  arc 9 10 ($rout 0 #calc "$h1")
  arc 12 15 ($rin 0 #calc "$h1+$delh")
  arc 13 14 ($rout 0 #calc "$h1+$delh")
  arc 16 19 (#calc "$rin+$dr1" 0 #calc "$h1")
  arc 17 18 (#calc "$rout+$dr2" 0 #calc "$h1")
  arc 20 23 (#calc "$rin+$dr1" 0 #calc "$h1+$delh")
  arc 21 22 (#calc "$rout+$dr2" 0 #calc "$h1+$delh")
boundary
    inlet
        type patch;
       faces
            (0 3 2 1)
    walls
        type wall;
       faces
            (7 3 0 4)
            (12 15 11 8)
            (2 6 5 1)
    wedge1
        type symmetry;
       faces
            (5 4 0 1)
            (8 9 13 12)
            (16 17 21 20)
    wedge2
        type symmetry;
       faces
            (3 7 6 2)
            (15 14 10 11)
            (23 22 18 19)
    top_walls
        type wall;
       faces
            (16 19 18 17)
            (12 13 14 15)
            (20 21 22 23)
    outlet
        type patch;
       faces
            (21 17 18 22)
//    defaultFaces
//        type empty;
//        faces
//            (4 5 6 7)
//            (8 9 10 11)
//            (23 20 16 19)
//            (14 13 9 10)
interface1
type empty;
faces
((4 5 6 7));
interface2
type empty;
faces
((8 9 10 11));
interface3
type empty;
faces
((23 20 16 19));
interface4
type empty;
faces
((14 13 9 10));
mergePatchPairs
(interface1 interface2)
I would be thankful if anyone has pointed where I am making mistake. I have spent considerable time in this problem
Thank you,
Parth
parthigcar is offline   Reply With Quote
Old   April 12, 2021, 11:32
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
We are not talking about a real pressure for incompressible solvers. The only thing that matters is the pressure gradient which you set with fixedValue. However, you inlet and outlet do have a fixedValue condition which tells you to have a fixed pressure gradient (static pressure).
Based on your boundary conditions, your mass-flow should increase to infinity as you don´t reduce the pressure gradient - for example - reduce the inlet pressure by the dynamic pressure.
The solution of your problem should be easy:
  • Set the inlet boundary to totalPressure
That condition reduces the static pressure at the faces according to the dynamic pressure and keeps the total pressure equal (to the value you specified). Hence, you get an equilibrium between acceleration of your fluid and the pressure gradient.
By the way. If you inlet pressure is around 0.21 MPa, you need to know which pressure you mention here. Is it the total pressure or the static pressure?
You need to know the pressure at the outlet correpsonding to the same type of the inlet. Here, 0.21 MPa corresponding to your outlet is the static-pressure gradient.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   April 12, 2021, 12:03
parth
Dear Tobi...!!
Thank you for your reply. I understood it should be total pressure at the inlet.
I have really learnt a lot from your youtube videos, they are very much informative.
Best regards,
Parth
Tobi likes this.
openfoam1912, pimplefoam, pressure boundary, pressure driven flow, velocity boundary
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 06:21
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
