cyclicAMI "bounding boxes are not similar" error |
saidc
Rep Power: 6 ![]() |
I'm simulating a natural convection turbulent flow in a box geometry. Inside the box I've a stl file. I cannot share my all mesh but for better understanding HERE there've a quick draw. Case folder and log files have atteched without stl file. I was working with Foundation v8, but since there is no "heatTransferCoefficient" function there, I decided to work with ESI. With Foundation I haven't got any error. My case works fine. But in ESI I'm getting this error while decomposePar. Code:
Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical [4] Finished decomposition in 2.88 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Reading hexRef8 data : cellLevel Reading hexRef8 data : pointLevel Reading hexRef8 data : level0Edge Processor 0 Number of cells = 788380 Number of faces shared with processor 1 = 8091 Number of faces shared with processor 2 = 7646 Number of faces shared with processor 3 = 9 Number of processor patches = 3 Number of processor faces = 15746 Number of boundary faces = 174765 Processor 1 Number of cells = 788380 Number of faces shared with processor 0 = 8091 Number of faces shared with processor 3 = 7864 Number of processor patches = 2 Number of processor faces = 15955 Number of boundary faces = 162934 Processor 2 Number of cells = 788380 Number of faces shared with processor 0 = 7646 Number of faces shared with processor 3 = 7911 Number of processor patches = 2 Number of processor faces = 15557 Number of boundary faces = 162985 Processor 3 Number of cells = 788381 Number of faces shared with processor 0 = 9 Number of faces shared with processor 1 = 7864 Number of faces shared with processor 2 = 7911 Number of processor patches = 3 Number of processor faces = 15784 Number of boundary faces = 152356 Number of processor faces = 31521 Max number of cells = 788381 (9.51318e-05% above average 788380) Max number of processor patches = 3 (20% above average 2.5) Max number of faces between processors = 15955 (1.2341% above average 15760.5) Time = 0 AMI: Creating addressing and weights between 10800 source faces and 10800 target faces --> FOAM Warning : From void Foam::advancingFrontAMI::checkPatches() const in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 71 Source and target patch bounding boxes are not similar source box span : (0 80 240) target box span : (0 80 240) source box : (-40 -40 -120) (-40 40 120) target box : (120 -40 -120) (120 40 120) inflated target box : (107.351 -52.6491 -132.649) (132.649 52.6491 132.649) AMI: Patch source sum(weights) min:0.999999 max:1 average:1 AMI: Patch target sum(weights) min:0.999999 max:1 average:1 AMI: Creating addressing and weights between 10800 source faces and 10800 target faces --> FOAM Warning : From void Foam::advancingFrontAMI::checkPatches() const in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 71 Source and target patch bounding boxes are not similar source box span : (80 0 240) target box span : (80 0 240) source box : (-40 -40 -120) (40 -40 120) target box : (-40 120 -120) (40 120 120) inflated target box : (-52.6491 107.351 -132.649) (52.6491 132.649 132.649) AMI: Patch source sum(weights) min:0.999999 max:1 average:1 AMI: Patch target sum(weights) min:0.999999 max:1 average:1 Processor 0: field transfer Processor 1: field transfer Processor 2: field transfer Processor 3: field transfer End Code:
AMI: Creating addressing and weights between 10800 source faces and 10800 target faces --> FOAM Warning : From void Foam::advancingFrontAMI::checkPatches() const in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 71 Source and target patch bounding boxes are not similar source box span : (0 80 240) target box span : (-2e+150 -2e+150 -2e+150) source box : (-40 -40 -120) (-40 40 120) target box : (1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) inflated target box : (8.26795e+149 8.26795e+149 8.26795e+149) (-8.26795e+149 -8.26795e+149 -8.26795e+149) --> FOAM Warning : From bool Foam::advancingFrontAMI::initialiseWalk(Foam::label&, Foam::label&) in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 132 5760 source faces but no target faces AMI: Patch source sum(weights) min:0 max:0 average:0 AMI: Patch target sum(weights) min:0 max:0 average:0 AMI: Creating addressing and weights between 10800 source faces and 10800 target faces --> FOAM Warning : From void Foam::advancingFrontAMI::checkPatches() const in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 71 Source and target patch bounding boxes are not similar source box span : (80 0 240) target box span : (-2e+150 -2e+150 -2e+150) source box : (-40 -40 -120) (40 -40 120) target box : (1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) inflated target box : (8.26795e+149 8.26795e+149 8.26795e+149) (-8.26795e+149 -8.26795e+149 -8.26795e+149) --> FOAM Warning : From bool Foam::advancingFrontAMI::initialiseWalk(Foam::label&, Foam::label&) in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 132 5760 source faces but no target faces AMI: Patch source sum(weights) min:0 max:0 average:0 AMI: Patch target sum(weights) min:0 max:0 average:0 For quick look Allrun script Code:
runApplication blockMesh runApplication snappyHexMesh -overwrite runApplication createPatch -overwrite runApplication decomposePar runParallel $(getApplication) runApplication reconstructPar Error on decomposePar with cyclicAMI Problems using reconstructPar on a case involving AMI I'm open any advice. Kind Regards, Said. |
Tobias
Rep Power: 0 ![]() |
Hello Said,
You need to change the sign of the separationVector in your createPatchDict. The separationVector is one of the things that ist defined differently depending on the variant and version of OpenFOAM. You can see this in the warning. The source box is the given patch and the target box the transformed neighbourPatch. So the target box should have the same values as the source box. In the first warning the x-coordinates are 80 above the values of the neighbourPatch leading to 120. So changing the sign of the separationVector will lead to the correct values. |
#3 | |
saidc
Hi Tobias, I tried your advice and it worked well for me. As you said I just change the sign of the separationVector. Thanks a lot for your reply. Kind Regards, Said. Last edited by saidc.; April 11, 2021 at 09:25. |
#4 | |
CFD_Lovers
Rep Power: 11 ![]() |
I am not able to find a certain clear definition for separationVector. I am trying to make a fully developed flow in a nozzle before it exits the outlet into a tank. I want to simulate the nozzle with cyclic boundary condition and get the error as discussed above. How one can determine the separationVector for each case? Thanks, Sina |
cyclicami, natural convectin |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
