Mark
Rep Power: 9 ![]() |
Has anyone had any problems with running OF with open mpi 4.0.3.
I had been using OF1912 which came with Open MPI 1.10.7. Today I tried using OF2012 which comes with Open MPI 4.0.3. I am getting the "There are not enough slots available in the system...." and it appears that the number of slots the Open MPI sees is just the number of cores, not threads. Same decomposeParDict. I am using Ubuntu 20.04 on two different boxes. One is a native install, the other is WSL2 on a Win10 box. Both boxes are AMD Threadripper workstations. Thoughts? |
Abe
Rep Power: 10 ![]() |
I don't think you will see a speedup if you run the number of processors equal to the number of threads, rather than cores, but you should try it and report back to us! I think you can do this by running, for example with 4 cores and 2 threads each:
mpirun -np 8 --bind-to hwthread verses: mpirun -np 4 --bind-to core I could be wrong, but give it a try and see what happens. |
Mark
results:
> np 32 / hwthread: 3m-17s > np 16 / core: 2m-38s Wow! |
Abe
Yay! Now you can move on with your life until the next problem!
Dominik Mütter
Rep Power: 5 ![]() |
You can also oversubscribe the number of slots in openmpi with "mpirun -np x --oversubscribe"
mpi, of2012, open mpi |
openFOAM mpirun error on cluster | cheng1988sjtu | OpenFOAM Running, Solving & CFD | 1 | November 14, 2012 22:13 |
