laplaceFaceDecomposition for simpleEngine tutorial isnt available in foam-extend-4.1 |
Salah Gaffar
Rep Power: 9 ![]() |
Hello foamers,
I am trying to simulate the simpleEngine problem posted by Dr. Hrvoje Jasak in an earlier post in 2011-2012 using foam-extend-1.6 (if i understand correctly), but unfortunately, the laplaceFaceDecomposition motion solver seems to be gone from the current foam-extend version. I had a few questions for more experienced foamers. 1) Does anyone understand the history of this solver omission decision? 2) What is the recommended alternative by the community for this example and is there a more recent version of the simpleEngine tutorial that Dr. Jasak's one in the 2011-2012 blogpost? 3) Is there someone in the community that is also interested in this problem and can collaborate with me to extend the simpleEngine tutorial to more complex geometry (4-stroke tilted valve DI engine problem)? I really appreciate your help and thank you in advance. Keep foaming ![]() P.S. link for 2011-2012 blogpost is as follows: engine simulation with mesh motion and topological changes with reply number 64 as the link to the tutorial (requires modifications available in the comments below the tutorial link) |
dynamicfvmesh;multiregion, engine mesh motion, foam-extend-4.1, laplacefacedecomposition, simpleengine |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
Block coupling three equations using foam extend 4.1 | ELwardi | OpenFOAM Programming & Development | 2 | March 19, 2019 10:35 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 29, 2015 23:42 |
