Compressible flows with larger Courant numbers |
February 25, 2021, 06:51 |
Tobias Holzmann
Rep Power: 52 |
Hey all,
I need support from the community - especially from the people who deal with compressible flows. At the moment I have a case similar to the motorbike tutorial. However, its not a motor bike but rather a building. Right now I am using the ESI2012 version as we have the atmospheric boundary layer boundary condition available here. The building does have intake channels that distribute air to the single HVAC systems. The question is, how does the pressure change inside these intake channels if we have a gust of wind attacking the building. The side walls and top are slip conditions (far away from the building). The inlet is a atmospheric boundary layer condition using a Function1 velocity ramp (from 11.11 m/s to 22.22 m/s). For testing purposes, I first used [i]simpleFoam{/i] and pimpleFoam which is not 100 % correct based on compression effects and even the physics are not correct (missing variable density based on pressure and also energy is missing). However, using pimpleFoam I can reach Courant numbers up to 80 and more. I changed the case to run with rhoSimpleFoam and rhoPimpleFoam. Here, I first encountered new phenomenon (traveling pressure waves). I guess I have to set the waveTransmissive boundary condition for the outlet for the pressure and maybe an advective condition (not sure here right now). Nevertheless, I am only able to increase the Courant number up to 2 - not more. I am using (of course) the PIMPLE algorithm and under-relaxation. As I am not in the sonic regime, I did not set the transonic keyword and hence I am not able to under-relax (or at least create a dominant diagonal matrix for p). Based on my experience I would expect that I am doing something wrong here. I don't want to believe that we cannot go beyond Co >> 1 if the case is compressible rather than incompressible - even though the physics are different. I tested different things:
Any suggestions? The problem I encounter
Courant Number mean: 0.00279342 max: 4.08089 deltaT = 0.00161032 Time = 0.00974201 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 3.5732e-05, Final residual = 9.43131e-10, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1.77416e-06, Final residual = 4.68944e-10, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 5.30558e-06, Final residual = 1.20359e-09, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00502815, Final residual = 1.20277e-07, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 286.177 Unlimited Tmin 281.833 GAMG: Solving for p, Initial residual = 0.00370735, Final residual = 2.4247e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 4.16185e-06, Final residual = 1.87928e-07, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.75802e-07, global = -1.5708e-07, cumulative = -9.11225e-07 GAMG: Solving for p, Initial residual = 0.000633883, Final residual = 3.65278e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 6.31271e-07, Final residual = 7.4593e-09, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.36062e-12, global = 5.56526e-14, cumulative = -9.11225e-07 smoothSolver: Solving for epsilon, Initial residual = 1.37184e-07, Final residual = 2.12954e-11, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.000194329, Final residual = 4.47227e-09, No Iterations 1 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 6.71046e-06, Final residual = 1.7621e-10, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 3.79105e-07, Final residual = 1.09837e-10, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1.19544e-06, Final residual = 2.98125e-10, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.0029649, Final residual = 7.26531e-08, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.863 Unlimited Tmin 281.961 GAMG: Solving for p, Initial residual = 0.000174809, Final residual = 1.49358e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 2.57472e-07, Final residual = 1.657e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.0362e-07, global = -9.28018e-08, cumulative = -1.00403e-06 GAMG: Solving for p, Initial residual = 0.000331244, Final residual = 1.25984e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 2.60139e-07, Final residual = 1.96456e-09, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.21801e-13, global = 3.70125e-14, cumulative = -1.00403e-06 smoothSolver: Solving for epsilon, Initial residual = 2.76842e-08, Final residual = 8.41864e-12, No Iterations 1 smoothSolver: Solving for k, Initial residual = 3.88806e-05, Final residual = 9.03391e-10, No Iterations 1 PIMPLE: iteration 3 smoothSolver: Solving for Ux, Initial residual = 1.32247e-06, Final residual = 3.4981e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 7.60266e-08, Final residual = 2.23339e-11, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 2.56208e-07, Final residual = 6.56247e-11, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00211488, Final residual = 5.02073e-08, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.755 Unlimited Tmin 281.964 GAMG: Solving for p, Initial residual = 2.8028e-05, Final residual = 2.66913e-08, No Iterations 1 GAMG: Solving for p, Initial residual = 4.83756e-08, Final residual = 2.77015e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 7.40606e-08, global = -6.68686e-08, cumulative = -1.0709e-06 GAMG: Solving for p, Initial residual = 0.000234569, Final residual = 7.68287e-08, No Iterations 1 GAMG: Solving for p, Initial residual = 1.59744e-07, Final residual = 5.63652e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.78429e-12, global = -4.88732e-14, cumulative = -1.0709e-06 smoothSolver: Solving for epsilon, Initial residual = 5.67815e-09, Final residual = 5.67815e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 7.79026e-06, Final residual = 1.87077e-10, No Iterations 1 PIMPLE: iteration 4 smoothSolver: Solving for Ux, Initial residual = 3.26645e-07, Final residual = 1.20878e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 2.28174e-08, Final residual = 1.02859e-11, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 7.88249e-08, Final residual = 3.12497e-11, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00277312, Final residual = 1.04193e-09, No Iterations 2 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.706 Unlimited Tmin 281.964 GAMG: Solving for p, Initial residual = 0.000320839, Final residual = 2.66004e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 4.41056e-06, Final residual = 2.37098e-07, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 9.73856e-08, global = -8.82307e-08, cumulative = -1.15913e-06 GAMG: Solving for p, Initial residual = 0.000310503, Final residual = 2.90832e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 4.98479e-07, Final residual = 8.40567e-09, No Iterations 10 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.6592e-12, global = -3.37186e-13, cumulative = -1.15913e-06 smoothSolver: Solving for epsilon, Initial residual = 6.05477e-09, Final residual = 6.05477e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 1.5925e-06, Final residual = 6.24265e-11, No Iterations 1 PIMPLE: converged in 4 iterations ExecutionTime = 660.36 s ClockTime = 663 s Courant Number mean: 0.00333044 max: 4.86715 deltaT = 0.00191705 Time = 0.0116591 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 4.21722e-05, Final residual = 1.36e-09, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 2.03304e-06, Final residual = 6.55644e-10, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 6.61419e-06, Final residual = 1.64793e-09, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00706587, Final residual = 1.86213e-07, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.658 Unlimited Tmin 281.965 GAMG: Solving for p, Initial residual = 0.00516715, Final residual = 3.4496e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 5.72715e-06, Final residual = 2.94899e-07, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.49377e-07, global = -2.28596e-07, cumulative = -1.38772e-06 GAMG: Solving for p, Initial residual = 0.000900441, Final residual = 5.11039e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 8.4405e-07, Final residual = 3.35456e-09, No Iterations 3 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.05999e-12, global = -1.28249e-13, cumulative = -1.38772e-06 smoothSolver: Solving for epsilon, Initial residual = 1.61668e-07, Final residual = 2.96927e-11, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.000227909, Final residual = 6.43739e-09, No Iterations 1 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 7.8078e-06, Final residual = 2.48281e-10, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 4.28789e-07, Final residual = 1.50638e-10, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1.47366e-06, Final residual = 4.13119e-10, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00412939, Final residual = 1.11931e-07, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.342 Unlimited Tmin 282.012 GAMG: Solving for p, Initial residual = 0.000241805, Final residual = 2.35327e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 3.73684e-07, Final residual = 2.57169e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.46523e-07, global = -1.34054e-07, cumulative = -1.52178e-06 GAMG: Solving for p, Initial residual = 0.000468784, Final residual = 1.82009e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 3.4669e-07, Final residual = 2.84362e-09, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 8.99333e-13, global = 3.45996e-14, cumulative = -1.52178e-06 smoothSolver: Solving for epsilon, Initial residual = 3.2656e-08, Final residual = 1.30227e-11, No Iterations 1 smoothSolver: Solving for k, Initial residual = 4.55782e-05, Final residual = 1.30011e-09, No Iterations 1 PIMPLE: iteration 3 smoothSolver: Solving for Ux, Initial residual = 1.53468e-06, Final residual = 4.91049e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 8.5587e-08, Final residual = 3.06683e-11, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 3.1383e-07, Final residual = 9.17849e-11, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00293931, Final residual = 7.76214e-08, No Iterations 1 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.22 Unlimited Tmin 281.989 GAMG: Solving for p, Initial residual = 3.87494e-05, Final residual = 4.18546e-08, No Iterations 1 GAMG: Solving for p, Initial residual = 6.93822e-08, Final residual = 4.78121e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.04781e-07, global = -9.65077e-08, cumulative = -1.61828e-06 GAMG: Solving for p, Initial residual = 0.000332077, Final residual = 1.12904e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 2.13438e-07, Final residual = 8.92377e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.82342e-12, global = -7.74067e-14, cumulative = -1.61828e-06 smoothSolver: Solving for epsilon, Initial residual = 6.71927e-09, Final residual = 6.71927e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 9.13119e-06, Final residual = 2.70368e-10, No Iterations 1 PIMPLE: iteration 4 smoothSolver: Solving for Ux, Initial residual = 3.78258e-07, Final residual = 1.71021e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 2.56664e-08, Final residual = 1.46649e-11, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 9.75395e-08, Final residual = 4.50279e-11, No Iterations 1 smoothSolver: Solving for h, Initial residual = 0.00385193, Final residual = 1.5891e-09, No Iterations 2 limitTemperature limitT Lower limited 0 (0%) of cells limitTemperature limitT Upper limited 0 (0%) of cells limitTemperature limitT Unlimited Tmax 285.164 Unlimited Tmin 281.977 GAMG: Solving for p, Initial residual = 0.000403112, Final residual = 3.93352e-06, No Iterations 1 [7] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [7] #1 Foam::sigFpe::sigHandler(int) at ??:? [7] #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 [7] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [7] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [7] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [7] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [7] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [7] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [7] #9 ? in ~/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam [7] #10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 [7] #11 ? in ~/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam [cfd:02852] *** Process received signal *** [cfd:02852] Signal: Floating point exception (8) [cfd:02852] Signal code: (-6) [cfd:02852] Failing at address: 0x3e800000b24 [cfd:02852] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7f6e48d943c0] [cfd:02852] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xcb)[0x7f6e48d9424b] [cfd:02852] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7f6e48d943c0] [cfd:02852] [ 3] /home/shorty/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xee)[0x7f6e497a452e] [cfd:02852] [ 4] /home/shorty/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x1668)[0x7f6e497a7028] [cfd:02852] [ 5] /home/shorty/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x625)[0x7f6e497a8535] [cfd:02852] [ 6] /home/shorty/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x191)[0x7f6e4d74b741] [cfd:02852] [ 7] /home/shorty/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x413)[0x7f6e4cf598a3] [cfd:02852] [ 8] /home/shorty/OpenFOAM/ESI/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28)[0x7f6e4cef3cf8] [cfd:02852] [ 9] rhoPimpleFoam(+0x38c10)[0x5615799f3c10] [cfd:02852] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f6e48bb40b3] [cfd:02852] [11] rhoPimpleFoam(+0x3c21e)[0x5615799f721e] [cfd:02852] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 7 with PID 0 on node cfd exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- shorty@ALU-40-1st-large-rho:
If you need more information regarding the case set-up etc. let me know. Maybe important. Inside the building is the air-distribution channel for the HVAC devices. I do have 24 sub-channels that suck air out of the domain (at the moment all these patches do have fixedValue velocity conditions). Maybe a mass-flow based outlet is more appropriate which gets a more reliable pressure distribution? However, again, I am not sure about the pressure conditions there (right now zeroGradient).
Keep foaming, Tobias Holzmann Last edited by Tobi; February 25, 2021 at 14:52. |
February 25, 2021, 12:45 |
Rep Power: 14 |
What is the problem with the simulation, Tobi? Presumably it is unstable/diverges? If so, which field is causing the trouble?
You mentioned that you are simulating an ABL ... is the domain height very tall? What happens if you apply the same BCs on an empty box with similar background mesh density ... does it still misbehave? |
February 25, 2021, 14:53 |
Tobias Holzmann
Rep Power: 52 |
Hey Tobermory,
thank you for your reply. Honestly, my fault - I always tell the people to give enough information and I miss it too. I added the important part and would like to share the case but it is confidential - unfortunately.
Empty-Box-Check
Probably based on the pressure boundary conditions. The empty box case is available here: https://Holzmann-cfd.com/forum/compr...mptyBox.tar.gz
Keep foaming, Tobias Holzmann |
February 25, 2021, 15:30 |
Rep Power: 15 |
Hi all,
A few thoughts that hopefully may add to the discussion : In my experience, simulating compressible flows in openfoam can be quite finicky... When prescribing a velocity at a patch, I've found that using a fixedFlux pressure bc is better and more stable than using a zeroGradient (if you are not already). Indeed, the outlet pressure bc can also be problematic; I've also had fair success using the same configuration of waveTransmissive for pressure, and inletOutlet/pressureInletOutlet for velocity. With regard to seeing pressure waves specifically, the wave transmissive bc should help them escape the domain... another option may be to keep the domain as coarse as possible away from the building, hoping that numerical dissipation may help with the waves as well. Depending on your modeling objective, you may also be able to make use of local time stepping to accelerate convergence, if only for a spinup case to maybe initialize the domain -- for instance to ~11m/s before you increase the velocity. I noticed that you are using rhoPimpleFoam -- there is a rhoPimpleAdiabaticFoam solver for "weakly compressible flows for low Mach number aeroacoustic applications" which may be worth checking out. Finally, I noticed that you're likely using some form of k-Epsilon for turbulence modling -- have you tried a k-omega model? Anecdotally, I've gotten away with Co closer to 5 with kOmegaSST... a far cry from 80, though. Hope some of the above may be useful, Caelan |
February 26, 2021, 14:10 |
Tobias Holzmann
Rep Power: 52 |
Dear Caelan,
Thank you very much for your feedback. I did not use a fixedFluxPressure BC as this should help if we have body forces acting on the fluid (but we don't have anything here such as gravity or buoyancy), hence the zeroGradoent and fixedFlux should be identical - however to make a complete statement I should recheck the fixedFlux BC. I used kOmegaSST at the beginning but kEpsilon was more stable and should work for an initial step. To clarify: I don't need to go to Co ~ 80 but fairly larger than 1 or 2. And additional, I was just curious about not reaching higher Courant numbers while using the Pimple algorithm. Nevertheless, as I already pointed out, I only have limited experience and knowledge regarding compressible flows. The solver you mentioned is interesting, I will check it out. Saw it yesterday in the evening but I had no time to check the implementation and the differences between both solvers. By the way, the LTS pre calculation is a good hint. However, as I mentioned, I start from a steady state solution from RhoSimpelFoam
February 26, 2021, 16:20 |
Rep Power: 15 |
Hi Tobi,
Good point about fixedFlux -- at some point I must have automatically started using it for all my compressible cases. With regard to the LTS initialization, I'd just meant it as another option... sometimes I think that LTS spinup may end up being faster than spinup with a steady solver. I'll be interested to know what you think of the rhoPimpleAdiabaticFoam solver. Caelan
Public git repository : https://github.com/clapointe2011/public |
Actual Courant Numbers much greater than maxCo in interFoam with Local Time Stepping | Ship Designer | OpenFOAM Running, Solving & CFD | 16 | August 5, 2022 12:08 |
icoFoam crashing due to high courant numbers | Thomas44 | OpenFOAM Running, Solving & CFD | 6 | January 26, 2021 12:01 |
Low Mach Number Compressible Multiphase Flows | DarrenC | CFX | 10 | May 26, 2014 09:52 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
