Large Eddy Simulation - pisoFoam or pimpleFoam?
Like Tree1Likes
  • 1 Post By Tobermory
Old   February 16, 2021, 16:40
Default Large Eddy Simulation - pisoFoam or pimpleFoam?
erickmartinez's Avatar
Erick D. Martinez
erickmartinez is on a distinguished road
Good day OpenFOAMers! I am currently doing research on the LES of a Wave Energy Converter and I wanted to ask for some input. Does any solver work better under certain conditions for LES? I am wondering whether piso or pimpleFoam would work better. Additionally, would you know if both solvers work well with Arbitrary Mesh Interface motion? I have used pimpleFoam for AMI but I am wondering if pisoFoam supports it as well.
I would appreciate any input! Thank you in advance.
erickmartinez is offline   Reply With Quote
Old   February 16, 2021, 16:51
Tobermory will become famous soon enough
For the first part of the question - pimple or piso - well, since you are running LES, you'll be ensuring Co<1, probably Co~0.3. In which case you don't get any benefit from the additional pressure correctors that allow the pimple solver to stretch the Co number to 10 and beyond. So, you basically want to be running piso.
Having said that - you can run pimpleFoam in "piso mode" by just limiting nOuterCorrectors to 1 (ie one pimple iteration per time step) and nCorrectors to 2 (ie two inner loop pressure correctors). That will then give you access to the other features of the pimpleFoam solver.
Hope that helps.
FaroukH likes this.
Tobermory is offline   Reply With Quote
Large Eddy Simulation Nijanthan FLUENT 14 May 3, 2021 16:32
Introductory books on Large Eddy Simulation q.z. Main CFD Forum 5 September 20, 2016 06:32
Large eddy simulation for flow around cylinder ash_kul999 OpenFOAM Running, Solving & CFD 5 April 18, 2015 05:47
Mean flow field in Large Eddy Simulation Servantes STAR-CCM+ 1 September 11, 2014 18:32
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
