activePressureForceBaffleVelocity
Like Tree2Likes
  • 1 Post By Tobi
  • 1 Post By CBranch171
Old   February 10, 2021, 05:10
Default activePressureForceBaffleVelocity
London
CBranch171 is on a distinguished road
Hi, I'm look for any openfoam example that uses activePressureForceBaffleVelocity as a boundary condition. I understand it requires two cycle patches but I struggling to see this implemented anywhere.
I would like to use this for modelling a bursting disk. So when the pressure gets to a certain value the baffle opens and allows flow into the downstream domain from master to slave.
I currently have an example that uses a pressure jump for an actuator disk would this serve as a basis and I substitute the activePressureForceBaffleVelocity BC. I basically want to make sure I have all the correct syntax.
CBranch171 is offline   Reply With Quote
Old   October 8, 2021, 15:37
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Still interested or almost over?
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 9, 2021, 07:09
London
Hi yes I’m still interested in getting a working example on this
Thanks
Old   October 11, 2021, 17:32
Tobi's Avatar
Tobias Holzmann
Hey,
I am working on a new tutorial that I will publish on my website. The aim is to simulate a vessel which does have a valve that opens after a defined pressure difference is reached (such as a rapture disc or safety valve). An impression is given below.
However for a first idea it is as follows:
  • Create your geometry (here the tank)
  • Use topoSet to create a face set. The face set includes all faces that are representing the rapture disc (or a valve or anything else). One can also add it to the snappyHexMeshDict to get a correct surface representation. However, the faces should be selected using topoSet
  • Convert the face set into a faceZone (also done in topoSet)
  • Use createBaffles to quadroplicate (nice word) the faces
    • a couple of cyclic patches
    • a couple of wall patches
  • Use createPatch to merge the walls into one patch (checkMesh will throw an error but its okay)
  • You are ready to go » for U apply the boundary condition on the merged wall patch and set the cyclic to the corresponding name
That's it.
If its to complicated, I will upload the case probably during the case.
acgnipper likes this.
Keep foaming,
Tobias Holzmann
Old   October 14, 2021, 02:57
Tobi's Avatar
Tobias Holzmann
Hey,
I finished the case and published it on my website. Enjoy.
Tobi
Keep foaming,
Tobias Holzmann
Old   October 14, 2021, 03:49
Default Baffles etc
London
Thanks I will go through it
Much apresciated.
Tobi likes this.
Old   November 24, 2022, 06:34
Default Openfoam 10 versus 2112
London
Hi Tobi
I am still working on this problem. I am using openfoam 10 and you have used openfoam 2112. Is there a reason for you switching to openfoam 2112. I cannot get this to work, i.e. create the 4 required patches with openfoam 10. I just post a question on this.
Old   November 24, 2022, 12:33
Tobi's Avatar
Tobias Holzmann
I am working within the team of ESI-OpenCFD, hence, I am involved into the developments here and also know whats released and whats going on
Thats why I used v2112.
Keep foaming,
Tobias Holzmann
Old   November 24, 2022, 13:39
London
Perfect. Nice to know why the change occurred. I can confirm 2206 is working and I get my cyclic patches and walls. Next step is to add the boundary condition.
Old   November 24, 2022, 13:57
Tobi's Avatar
Tobias Holzmann
Yes, because my patch was added to v2206.
Keep foaming,
Tobias Holzmann
Old   December 6, 2022, 05:39
Default use with twoPhaseEulerFoam
  #11
London
Hi Toby
I am using twoPhaseEulerFoam and have U.gas and U.water field. In your example you only have single U field. Do I apply the activePressureForceBaffleVelocity to each field so define it twice and do I need double the cyclic patches now.
i.e. you had 4 - 2 cyclic and 2 walls for a single U field
do I need 8 - gas (2 cyclic and 2 walls) and water (2 cyclic and 2 walls)
or can I use the same patches in the U.gas and U.water bc.
Thanks
bondary conditions
