Convergence problem with simpleFoam
Like Tree1Likes
  • 1 Post By petros
Old   January 21, 2021, 12:58
Default Convergence problem with simpleFoam
NewtonianGuy
NewtonianGuy is on a distinguished road
Hello! I am having an issue with simpleFoam (and am new to openFoam). In fact, the solution doesnt want to converge, specially the pressure. My case used the tutorial incompressible/simpleFoam/windaroundbuilding, and even this tutorial doesnt converge (didnt change anything...). If anyone can help or guide me I would really appreciate it!
case : flow around a structure (turbulence k-epsilon)
Below are my nschemes/fvsolution/controlDict files and 0 files. There's also the residuals plot (attached).
Thanks!
fschemes
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    limited         cellLimited Gauss linear 1;
    grad(U)         $limited;
    grad(k)         $limited;
    grad(epsilon)     $limited;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind limited;
    turbulence      bounded Gauss limitedLinear 1;
    div(phi,k)      $turbulence;
    div(phi,epsilon) $turbulence;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
fvsolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-6;
        relTol          0.1;
    "(U|k|omega|epsilon)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-6;
        relTol          0.1;
SIMPLE
    residualControl
        p               1e-4;
        U               1e-4;
        "(k|omega|epsilon)" 1e-4;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        "(k|omega|epsilon).*" 0.7;
controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         2000;
deltaT          1;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    //#includeFunc streamlines
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
//Uinlet          (10 0 0);
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    "inlet_bot|inlet_top"
        /*type            fixedValue;
        value           uniform $Uinlet;*/
		type       fixedProfile;
        profile    csvFile;
        profileCoeffs
            nHeaderLine         0;          // Number of header lines
            refColumn           0;          // Reference column index
            componentColumns    (1 2 3);    // Component column indices
            separator           ",";        // Optional (defaults to ",")
            mergeSeparators     no;         // Merge multiple separators
            file                "$FOAM_CASE/0/Uprofile3.csv";  // name of csv data file
            outOfBounds         clamp;      // Optional out-of-bounds handling
            interpolationScheme linear;     // Optional interpolation scheme
        direction        (0 1 0);
        origin           0;
    outlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    wall
        type            noSlip;
    #includeEtc "caseDicts/setConstraintTypes"
P
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
        type            zeroGradient;
    outlet
        type            totalPressure;
        p0              uniform 0;
    wall
        type            zeroGradient;
k
FoamFile
    version     2.0;
    format      ascii;
    object      k;
kInlet          0.015;   // approx k = 1.5*(I*U)^2 ; I = 0.1
internalField   uniform $kInlet;
boundaryField
        type            fixedValue;
        value           uniform $kInlet;
    outlet
        type            inletOutlet;
        inletValue      uniform $kInlet;
    wall
        type            kqRWallFunction;
epsilon
FoamFile
    version     2.0;
    format      ascii;
    object      epsilon;
epsilonInlet  2.755675961e-03; // Cmu^0.75 * k^1.5 / L ; L =10
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform $epsilonInlet;
boundaryField
        type            fixedValue;
        value           uniform $epsilonInlet;
    outlet
        type            inletOutlet;
        inletValue      uniform $epsilonInlet;
    wall
        type            epsilonWallFunction;
nut
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    wall
        type            nutkWallFunction;
        value           uniform 0;
NewtonianGuy is offline   Reply With Quote
Old   January 21, 2021, 17:00
Petros Ampatzidis
petros is on a distinguished road
The residuals seem that have reached convergence as they do not change any more. But that's only an indicator for a converged solution. Although, 0.1 might seem large, there other factors in that tutorial which may have an influence, e.g. the mesh, which is rather coarse. To understand convergence, you should monitor flow variables, mass flows etc. as well.
Best,
Petros
NewtonianGuy likes this.
petros is offline   Reply With Quote
pressure, simplefoam convergence
convergence problem with simpleFoam Ahmed Khattab OpenFOAM Running, Solving & CFD 1 July 20, 2017 11:23
simpleFoam - Convergence problem - Simple rectangular prism domain HakikiCanakkaleli OpenFOAM Running, Solving & CFD 5 May 9, 2013 05:59
Swirl flow convergence problem with simpleFoam iqbalsk8 OpenFOAM Running, Solving & CFD 7 November 28, 2012 01:54
simplefoam convergence problem Matt1986 OpenFOAM Running, Solving & CFD 6 October 16, 2012 09:32
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
