Bird Correction for Heat-Transfer Model (Particles) |
January 19, 2021, 08:43 |
Tobias Holzmann
Rep Power: 52 |
Dear Community,
I do have a question regarding the Bird Correction we can activate in the heat-transfer model in OpenFOAM. The question is related to the usage of the model.
After some short research, it seems that it is related to the Stefan Flow? However, I am not sure about that and maybe I am mixing things up here (probably). So if you are aware of that correction, I would be happy to have some information as return
Keep foaming, Tobias Holzmann |
April 30, 2021, 05:25 |
Rep Power: 7 |
I also want to know
May 18, 2021, 23:01 |
Jairo A. Gutiérrez S
Rep Power: 12 |
See in: https://pure.tue.nl/ws/files/9110053...02016_main.pdf
"Bird correction is applied to Nu to account the reduction in heat transfer due to evaporation". I suppose this is related to the change in Nu due to the vapour film near the droplet, which if my brain does not trick me, is related to the Stephan flow phenomena. In the code, it clearly seen that the BirdCorrection modifies the htc (heat transfer coefficient): if (BirdCorrection_ && (mag(htc) > ROOTVSMALL) && (mag(NCpW) > ROOTVSMALL)) { const scalar phit = min(NCpW/htc, 50); if (phit > 0.001) { htc *= phit/(exp(phit) - 1.0); // Always reduces the value of htc. } } return htc; } |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Enhanced wall treatment, low re k-e model, k-w model with low Re correction | junz | FLUENT | 0 | April 21, 2015 16:36 |
Interphase transfer model | sjtusyc | CFX | 1 | September 6, 2012 07:13 |
