It is possible OpenFoam saves only the velocity field in every timestep? |
Aina
Rep Power: 6 ![]() |
Dear all, currently I'm doing a 3D simulation using kOmegaSST. I need to save in every timestep the velocity field instead of all variable fields (k, omega, p, nut, etc.). It is possible?
I can't see in controlDict any option to do this. Thanks a lot! |
Rep Power: 15 ![]() |
I'm not sure how to do it without modifying the code (maybe someone can jump in here). But but to get you an answer this can be done by incorporating some small changes to e.g., pimpleFoam :
First, copy the solver and rename it to something like myPimpleFoam (make sure to update Make/files as well and have it compile to $FOAM_USER_APPBIN). Then, instead of Code:
runTime.write() Code:
//see if it is time to write data if (runTime.writeTime()) { //only write U U.write(); } |
Aina
It works exactly as you said
Thank you! ![]() Aina |
Federico Zabaleta
Rep Power: 10 ![]() |
Unless you want to make a cool video, I don't know why you would want to do that. If you need to postprocess every time-step it may be better to do it during the run-time and avoid saving lots of files that will occupy a lot of space in your hard-drive.
controldict, save variable field |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 08:34 |
change velocity field | LM4112 | OpenFOAM Running, Solving & CFD | 12 | February 5, 2014 11:56 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
