Apperance of mysterious He while trying to run reactingFoam solver |
January 11, 2021, 21:41 |
Mukund Gupta
Rep Power: 5 |
Dear Community,
I have been experiencing the appearance of mysteriously high amount of He concentration while trying to run reactingFoam solver under counterFlowDiffusionFlame2D case. This issue became predominant when I moved from OpenFOAM version 5 to version 7. I am trying to model hydrogen-oxygen combustion. Does anyone have any idea why this might be happening? |
January 12, 2021, 04:47 |
Does He appear as a species to repair mass conservation?
That is, does reactingFoam solve for N-1 species, where N is the amount of species in the reaction mechanism? Does the amount of He decrease/increase by changing the accurary of the time-stepping procedure, either by changing the time step or by changing the accuracy (atol and troll values) that govern the time step? |
January 12, 2021, 05:45 |
Gerry Kan
Rep Power: 11 |
Dear Mukund:
I looks like He is your inert species, as I see that it is being used a complement so that all mass fractions add up to one. If the amount of helium is not important, I would suggest leaving your chemistry set up as-is. Hope that helps, Gerry. Last edited by Gerry Kan; January 12, 2021 at 09:45. |
January 21, 2021, 22:07 |
Mukund Gupta
Rep Power: 5 |
Hi Gerry,
Thanks for your suggestion. Yes, He is being used so that all mass fractions add to 1. I am afraid I cannot leave the chemistry as it is because having some amount of He is important for the simulation I am trying to do. Do you have any other suggestion in mind that I can use? |
January 21, 2021, 22:09 |
Mukund Gupta
Rep Power: 5 |
Dear dlahaye,
Thanks for the suggestion, I will try this out and let you know what I am able to find? |
cfd, openfoam-7, reactingfoam |
modify reactingFoam in order to make it a steady state solver | Peoban2 | OpenFOAM Programming & Development | 9 | October 10, 2015 04:18 |
I just can't make this solver run | kickflipin | OpenFOAM Running, Solving & CFD | 7 | May 5, 2015 09:15 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
reactingFoam: ODE Solver KRR4 "Too many integration steps" | pajofego | OpenFOAM | 3 | May 18, 2013 16:15 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
