Radiation heat source in chtMultiRegion
Like Tree1Likes
  • 1 Post By julieng
Old   January 7, 2021, 07:26
Default Radiation heat source in chtMultiRegion
julien
julieng is on a distinguished road
I try to implement a heat source to take into account the external radiation from the ambient temperature on the interface between solid to fluid regions of a very simple test case using chtMultiRegionFoam solver.
My fvOption in the /solid directory is below:
HTML Code:
temperatureLimit
    type limitTemperature;
    active true;
    limitTemperatureCoeffs
        selectionMode all;
        min 290;
        max 10000;
heatSource
    type         scalarCodedSource;
    active       true;
    name         sourceTime;
    scalarCodedSourceCoeffs
         selectionMode   all;//cellSet
         //cellSet        externalRadiationcell;
        fields        (h);
       // fieldNames (T);
        redirectType sourceTime;
      //   name sourceTime;
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
            const scalar rhomat = 7850;
            const scalar emi = 0.9;
            const scalar Cp = 450;
            const scalar sigma = 5.670374e-8;
            const scalar Trad = 1000;
            const volScalarField& T = eqn.psi();          // sans cette ligne erreur
            scalarField& hSource = eqn.source();           //defining source
            // Iterating through patch
                word solid_to_fluid = coeffs().lookupOrDefault<word>("patch", "solid_to_fluid");
                const fvPatch& pp = mesh().boundary()[solid_to_fluid];
                forAll(pp, i) {
                label cell_i = pp.faceCells()[i];
               scalar Ai = pp.magSf()[i];
                scalar Ts = T[cell_i];
                hSource[cell_i] = sigma*emi*(pow4(Ts)-pow4(Trad))*Ai/rhomat/Cp;
            // Pout << V << endl; // retourne 3200 cells avec un volume de 0.00025 m3 soit 0.8m3 dans log
            // le cellSet comporte 400 cells soit 0.1 m3
            Pout << "***codeAddSup***" << endl;
            Pout << hSource << endl;
           // Pout << pp.magSf() << endl; // retourne la surface d'une cell 0.01m2
        codeSetValue
         //   Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
         $scalarCodedSourceCoeffs;
I have check that the selected cells surfaces where the heatsource term is applied is ok. The dimension of the heatsource is Km^2/s, I don't know if I need to have K/s or something else. I see on the forum that K/s is the correct dimension for volumic heat source.
I think that the problem is the magnitude in pow4(Ts) therm in the heatsource equation.
I have control the Ts value in the log and it seems that it is the h value instead of Temperature value with Ts=h/Cp. In consequense, my heatsource term is too large and the temperature explodes when I run the case.
I have try to put pw4(Ts/Cp) to put a temperature value inside the equation the heatsource term is too low. and the temperature of the surface is not increasing at all.
If I put the line // fieldNames (T); active, an error occurs.
I think that I am not too far the solution but as I don't understand exactly what happened I am not able to write the correct equation.
If someone knows how to resolve this, it would be very helpfull for me.
Best regards
Julien
julieng is offline   Reply With Quote
Old   January 7, 2021, 09:49
julien
Finally it works!!
Simply, I need to put W unit for the heatsource. It matches perfectly with other software.
dlahaye likes this.
Old   January 8, 2021, 15:37
julien
I need to monitor the value of the heatsource term added in the fvOption file.
I can see it in log file but for each cells of the patch. It is quite heavy in the log file and not very usable.
codeAddSup
Is there a way to create an independant file with my hSourve values via the controlDict file or from the fvOption file ?
Best regards
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
