boatAndPropeller tutorial error? overInterDyMFoam |
January 6, 2021, 12:17 |
Rep Power: 14 |
I've been playing a bit with the overInterDyMFoam tutorial boatAndPropeller that was included in OF v1806 and it seems to be an error. Once you run the case, the "propeller" rotates for a bit and then it stops. The rotation of the propeller is generated with a prescribedRotation restraint, and the "omega" value is passed as a table (Function1) in dynamicMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // motionSolverLibs (rigidBodyMeshMotion); dynamicFvMesh dynamicOversetFvMesh; motionSolver rigidBodyMotion; report on; solver { type Newmark; //gamma 0.1; // Velocity integration coefficient //beta 0.1; // Position integration coefficient } accelerationRelaxation 0.4; // prescribedRotation requires some sub-iterations to converge faster // to desired value of omega. nIter 3; bodies { hull { type rigidBody; parent root; // To get Tensor of Inertia (symmetrical) use surfaceInertia // here hull is empty shell mass 0.552; inertia (0.0033 0 0 0.01 0 0.0095); centreOfMass (0.2857 -0.07 0); // relative to the centreOfMass // of parent body // (here root = global coord system) // Transformation tensor and centre of rotation (CoR) transform (1 0 0 0 1 0 0 0 1) (0.2857 -0.07 0); joint { // These constrains are applied only to body hull, // other bodies need to have their own set // Constraints used for faster run type composite; joints ( { type Px; // Allow translation in X - } { type Ry; // Allow rotation along Y axis // (local - body CS) } ); } patches (hullWall); innerDistance 100; // With overset we want to avoid the mesh // deformation so have large innerDistance outerDistance 200; } propeller { type rigidBody; parent hull; centreOfMass (-0.2847 0.03 0); // Relative to parent CoM mass 0.0288; inertia (7.6e-6 0 0 4.2e-6 0 4.2e-6); // transform and CoR - relative to parent CoR transform (1 0 0 0 1 0 0 0 1) (-0.2757 0.03 0); patches (propellerWall); innerDistance 100; outerDistance 200; joint { type Rx; } } rudder { type rigidBody; parent hull; centreOfMass (-0.3602 -0.0055 0); mass 0.0746; inertia (3.3e-5 0 0 4.7e-6 0 3.4e-5); // transform and CoR - relative to parent CoR transform (1 0 0 0 1 0 0 0 1) (-0.3487 -0.04 0); patches (rudderWall); innerDistance 100; outerDistance 200; joint { type Ry; } } } restraints { rudderRotation { type prescribedRotation; body rudder; referenceOrientation (1 0 0 0 1 0 0 0 1); axis (0 1 0); // Axis of rotation omega sine; // Function1 entry omegaCoeffs { frequency 4; amplitude 0.2; scale (0 1 0); level (0 1 0); } } propellerRotation { type prescribedRotation; body propeller; referenceOrientation (1 0 0 0 1 0 0 0 1); axis (1 0 0); omega table ( (0 (0 0 0)) (1 (16 0 0)) ); } } I tried running the case with OF v1912, v2006 and v2012 with the same results. Any idea of what could be wrong? Thanks a lot! Federico. |
January 19, 2021, 11:15 |
Rep Power: 14 |
If it works for anyone, the prescribedRotation restraint acts as a controller applying a certain torque to the joint. This restraint is almost a direct copy of the angular spring restraint, but the controller doesn't work as expected.
I managed to modify the externalForce restraint, a lot cleaner than the angular spring, to apply a proportional controller based on torque, depending on the rotational speed of the propeller and with that obtain the desired value of omega. I don't think it's the ideal solution, in any case. Regards, Federico. |
August 4, 2021, 04:40 |
Hi
Shai Aser
Rep Power: 11 |
Hi Federico,
thank you for the update, are you willing to share your modification? Thanks again, Shai |
June 8, 2023, 11:10 |
Rep Power: 10 |
Hello Fredrico,
Could you share more details (or citations) about how to modify externalForce to control the torque? Thanks. |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 17:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 03:57 |
Tutorial For Workbench CFX Remesh | ashtonJ | CFX | 2 | April 26, 2014 22:19 |
Fluent Tutorial Guide Ch. 17: Non-Premixed Combust, THTR | MAE7509 | FLUENT | 0 | January 22, 2014 21:59 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 04:25 |
