December 28, 2020, 07:02 |
Chemkin file Reader error
sanjeev adhikari
Rep Power: 8 |
Hello everybody,
I was trying to write chem.inp for 9 Species 33 reactions. But while running the case I encountered the thread below: (OF231) --> FOAM FATAL ERROR: Third body not present on both sides of reaction on line 38 From function chemkinReader::lex() in file chemistryReaders/chemkinReader/chemkinLexer.L at line 1293. FOAM exiting For additional information, i have included the chem.inp file along with this thread. Thank you, in advance!!! |
December 28, 2020, 07:57 |
Should thou run chemkinToFoam first?
See https://www.openfoam.com/documentati...kinToFoam.html and the Sandia Flame D tutorial? |
December 28, 2020, 10:43 |
#3 | |
sanjeev adhikari
Rep Power: 8 |
Thank you for your suggestion. I tried chemkinToFoam <chemFile> <thermoFile> <newChem> <newThermo>. However, it gives same error as aforementioned. To be more specific, I extracted the combustion mechanism from the paper and wrote it in chemkin format. Can you please check it once. (Sorry, for incomplete info at first post) I have uploaded the chemkin and therm file along with combustion mechanism considered. |
December 29, 2020, 03:03 |
sanjeev adhikari
Rep Power: 8 |
chemfoam, chemicalkineticmechanism, chemkin gri, reacting foam |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
