spurious velocities with icoReactingMultiphaseInterFoam due to high surface tension |
December 26, 2020, 07:07 |
Rep Power: 6 |
Dear all, I'm using the icoReactingMultiphaseInterFoam solver to simulate the laser melting process. I have 3 components: Solid, liquid and gas. Everything works well as long as the surface tension is as low as 0.07 N/m. But spurious velocities occur and the simulation blows up, when I increase the surface tension to the physically correct value of 1.7 N/m, which is a typical value for liquid metals. It seems as if the spurious velocities occur in the area of the interface between gas and liquid/solid where melting or solidification takes place.
Can anyone give me a hint how to solve the problem? Many thanks! |
March 4, 2021, 06:56 |
#2 | |
Navid
Rep Power: 11 |
Well, it depends on your case characteristics. If you have a melt and solid, it means you have temperature gradient in your melt flow and thus you need to take care of marangoni force. in most cases , Maranogni compensates for the effects of surface tension force to some extent and thus alleviates the unwanted spurious currents at the surface, to a good degree. |
VOF +surface tension force modeling+ open channel flow+cyclic region= fatal error? | SJSW | Fluent Multiphase | 2 | November 18, 2014 05:15 |
Surface tension - normal or tangential ? | manxu | Main CFD Forum | 5 | October 23, 2013 13:39 |
Surface Tension Test Cases | sega | OpenFOAM Running, Solving & CFD | 2 | March 8, 2011 13:19 |
Surface Tension Gradient | Alisher | FLUENT | 0 | March 26, 2008 05:26 |
surface tension model in EX26 | Junhua Wu | FLUENT | 0 | June 7, 2000 11:49 |
