interFoam cup draining BC
Like Tree1Likes
  • 1 Post By joshmccraney
Old   December 25, 2020, 16:30
Default interFoam cup draining BC
Josh McCraney
joshmccraney is on a distinguished road
Hi All
I am running OF 6.0, interFoam. I have a cup with a hole at the bottom. The cup is partially filled with liquid, which flows out the bottom hole of the cup. The current BCs I have at the hole are:
alpha.water
    hole
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
p_rgh
    hole
        type            totalPressure;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 0;
        value           uniform 0;
U
    hole
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
Are these BCs appropriate? Thanks so much!
Mahmoud Abbaszadeh likes this.
joshmccraney is offline   Reply With Quote
Old   November 25, 2022, 05:33
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Originally Posted by joshmccraney View Post
Hi All
alpha.water
    hole
        type            inletOutlet;
        value           uniform 0;
p_rgh
    hole
        type            totalPressure;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 0;
        value           uniform 0;
U
    hole
I have the similar case working on. Did these BCs work for you? Thanks
Mahmoud Abbaszadeh is offline   Reply With Quote
Old   November 25, 2022, 12:03
Josh McCraney
Originally Posted by Mahmoud Abbaszadeh View Post
give me a few days to return to my workstation and i'll check. but whichever i used, it worked. i'll find it and post.
that being said, i pretty much went from this tutorial: https://wiki.openfoam.com/Multiphase...by_Jozsef_Nagy
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
Question about interFoam Solver Kahnbein.Kai OpenFOAM Running, Solving & CFD 2 August 26, 2019 16:36
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
interFoam (OpenFOAM) or general: pressure boundary conditions and tank draining SFr CFD Freelancers 6 June 15, 2016 08:11
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
