Difference OF7 to OF8 - hconst to econst
Like Tree1Likes
  • 1 Post By dlahaye
Old   December 8, 2020, 13:46
Default Difference OF7 to OF8 - hconst to econst
PSander is on a distinguished road
I recently tried to switch from OF7 to OF8. When I tried to run my chtMultiRegionFoam case I got the error messages of "Unknown solidThermo Type", so I had to change in thermophysicalProperties from "hConst" to "eConst", from "sensibleEnthalpy" to "sensibleInternalEnergy" and in fvSolution as well from h to e.
With this changes the case ran.
Checking here: https://cfd.direct/openfoam/user-gui...hermophysical/
the Thermodynamic models gives this explanation:
hConst
assumes a constant cp and a heat of fusion Hf which is simply specified by a two values cp Hf, given by keywords Cp and Hf.
eConst
assumes a constant cv and a heat of fusion Hf which is simply specified by a two values cv Hf, given by keywords Cv and Hf.
Running the case for 1000 seconds, gives me a tiny difference in results, but there is a difference. I know that OF6 and OF7 did not produce the same results either, but since I had to change from "hconst" to "econst", I would like to know, if there is any physical difference between cp and cv.
So is the difference in results just "normal", as I changed from OF7 to OF8, or is it a difference produced by different physical setting?
PSander is offline   Reply With Quote
Old   December 8, 2020, 14:11
Domenico Lahaye
dlahaye is on a distinguished road
Heat capacity of solid at constant volume (cv) or constant pressure (cp) can (and typically are) different. Tabular data will typically list both.
PSander likes this.
dlahaye is offline   Reply With Quote
Old   December 9, 2020, 04:40
Thank you for your help!
Since liquids and solids can practically assumed to be incompressible, Cp and Cv for them have almost same values at least at moderate temperatures?
Old   January 21, 2021, 08:32
JuanMi
keitaro7_14 is on a distinguished road
I noticed the same. Cp and Cv are practically the same for solid, so I guess the developers thought that for a solid it makes more sense eConst.
For the change of sensibleInternalEnergy, it seems to be for numerical reasons
https://github.com/OpenFOAM/OpenFOAM...25ab9817b3ec62
source: When choose sensibleInternalEnergy or sensibleEnthalpy in thermophysicalProperties
keitaro7_14 is offline   Reply With Quote
Old   February 4, 2021, 10:17
JuanMi
I noticed the same problem. I am solving a heat transfer model with two solids of different diffusivities and I get differences. I am still investigating where the trick is.
econst, hconst, openfoam 7, openfoam 8, thermophysicalproperties
equationOfState icoTabulated error carl_r OpenFOAM Running, Solving & CFD 3 March 14, 2022 07:05
WLF from OF7 Pisolino85 OpenFOAM 2 April 26, 2020 07:34
compile of new combination of property in thermophisicalpropery milad653279 OpenFOAM Running, Solving & CFD 4 April 6, 2017 05:35
Thermophysical properties for bouyantpimplefoam/chtmultiRegionfoam --water (any liq) manuc OpenFOAM Running, Solving & CFD 10 November 16, 2016 08:44
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
