Why is it difficult to get rhoSimpleFoam solver running correctly ?
Like Tree6Likes
  • 5 Post By HPE
  • 1 Post By HPE
Old   November 19, 2020, 03:42
Default Why is it difficult to get rhoSimpleFoam solver running correctly ?
ishan
ishan_ae is on a distinguished road
For the past two months I am trying to use rhoSimpleFoam( OF v6) to get results for my compressible subsonic internal flow. The solver refuses to not crash.
I have tried every trick I know; initialization using in compressible solution/inviscid solution, changed the boundary conditions, first order schemes, low relaxation factors, etc.
I know that the solver is sensitive to the values and settings. But having this much sensitivity makes it almost un-usable for me. Also, my case not complicated geometry wise as well as flow wise. It’s a simple duct with p_tot/t_tot at inlet and mass flow rate at outlet.
To investigate more on this, I have also tried to run a simple flow through a diffuser with a maximum Mach number of 0.15. I took this case from NASA’s validation archive and tried to run rhoSimpleFoam on it: https://www.grc.nasa.gov/www/wind/va.../fraser01.html
The solver crashes after 3 iterations.
Does anyone know why this solver is so sensitive? Has anyone used this solver in their studies ? If someone can provide some general guidelines for using this solver it will be helpful.
This will help other people as well, as going by the posts here I am not the only one encountering such problems.
ishan_ae is offline   Reply With Quote
Old   November 19, 2020, 06:50
Domenico Lahaye
dlahaye is on a distinguished road
Dear Ishan_ae,
There is truth and comfort in the statement that nothing is easy.
It is with interest that I read your posts in this forum. We have had our share of difficulties in making rhoSimpleFoam converge for our application. I much appreciate your tenacity in making the rhoSimple work.
I have two suggestions:
1/ please share details of the conical diffuser test case: geometry, mesh, boundary conditions, initial conditions etc
2/ let us discuss via conference call. I am available for instance on Friday, November 27th, Monday, November 30 th and Tuesday December 1st. I am in time zone GMT+1 (Amsterdam).
There is a chapter on compressible flow solvers in the book of Moukalled e.a. Not sure whether this helps.
Best wishes, Domenico Lahaye.
dlahaye is offline   Reply With Quote
Old   November 19, 2020, 07:20
ishan
Hello Domenico.
Thank you.
Of course we can connect via conference call on Friday Nov 27th Amsterdam time.This would be really helpful for me
We can discuss a mutually suitable time via PM. I will attach the files here as well in a while.
Regards,
Ishan
Old   November 19, 2020, 08:18
Domenico Lahaye
Wonderful. Pls. indicate time slot and make files available.
Thx, Domenico.
Old   November 19, 2020, 08:56
ishan
Hello
I have attached here the case files as well the reference paper: https://drive.google.com/drive/folde...pW?usp=sharing
It includes the mesh as well as the setup files. The setup and geometry resembles that of "Study#1" mentioned in the archive.
In its original form the case has been setup as 2D axisymmetric, total pressure and total temperature specified at inlet, and mass flux at outlet.
I have used a full 3D model with the same conditions at the inlet, but mass flow rate imposed at outlet. I did this for two reasons:
  1. I was not able to find the mass flux value that the authors have used.
  2. I don't know how in OpenFOAM we can impose any mass flow quantity when a 2D case is being simulated.
  3. A full 3D model simulation will allow me to understand on a very basic level what sort of settings work for rhoSimpleFoam solver since the case is not transonic/supersonic but subsonic. I could then replicate them on my actual model which has a max Mach number of 0.7.
  4. In the original numerical setup the authors have applied outlet BC at 0.15 metres downstream of the outlet. I have instead applied the BC at the outlet which corresponds to x=1.10 metres location.
I got the mass flow rate value from the "README" file mentioned on the archive page.
With regards to the time slot I PMed you.
EDIT - I have added to the list some more changes I did not menion.
Old   November 19, 2020, 14:44
Domenico Lahaye
See my reply on PM.
Old   November 19, 2020, 15:08
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Might using the following fvOptions help to avoid crashes:
- limitTemperature (particularly this one)
- limitVelocity
Note that `rhoSimpleFoam` is not a coupled solver. That explains myriad of reasons why the solver is somewhat numerically fragile. Have a review on such solver paradigms, please.
dlahaye, Junyan, ishan_ae and 2 others like this.
HPE is offline   Reply With Quote
Old   November 20, 2020, 01:58
ishan
Hello HPE.
Thanks for the info on the solver not being coupled. I have used both the quantity limiters in my original case.
With regards to the solver being fragile, which applications should be suitable for this solver ?
I think aerospace applications with M>0.6 will cause troubles. I have also observed that when flowRateOutletVelocity is imposed, the solver almost immediately becomes unstable if the relaxation factors are > 0.2.
Old   November 20, 2020, 09:24
HPE
HPE's Avatar
May be you wanna try:
https://hisa.gitlab.io/
ishan_ae likes this.
Old   November 23, 2020, 03:02
ishan
Hi HPE.
Thanks for the info on that solver. Looks interesting. I will try to run it once I sort out my current issue.
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
compressible solver rhosimplefoam "sigFe" error ruby_nuaa OpenFOAM Running, Solving & CFD 5 January 8, 2019 20:36
Running rhoSimpleFoam for Pressure Driven Flow y_jiang OpenFOAM Running, Solving & CFD 11 September 14, 2018 15:30
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
rhoSimpleFoam: solver error, iteration 2 seb_210 OpenFOAM Running, Solving & CFD 13 August 20, 2014 06:43
