What does the "value" field correspond to in OF BC ?
Like Tree1Likes
  • 1 Post By Yann
Old   November 4, 2020, 02:53
Default What does the "value" field correspond to in OF BC ?
ishan
ishan_ae is on a distinguished road
I have a question regarding the value field that we see in different OF BC.
I understand that if we use a fixedValue BC then for that value field we need to give a fixed value of the quantity of interest such as for velocity.
In BC such as flowRateOutletVelocity and calculated, what does this value field correspond to ? Are these initial values for the patches where these values have been specified ?
I looked into the user guide and here as well but could not get a conclusive answer.
ishan_ae is offline   Reply With Quote
Old   November 4, 2020, 03:25
geth03 is on a distinguished road
if you need detailed explanation you can check the description part of the header files. (nameOfFile.H)
here for example for flowRateOutletVelocity, you can see which information are needed and what they will do:
https://github.com/OpenFOAM/OpenFOAM...hVectorField.H
geth03 is offline   Reply With Quote
Old   November 4, 2020, 03:30
ishan
Thanks for information. Unfortunately I cannot read C++. If I have to find information on a BC I usually use foamInfo or go to openfoam.cpp.org/v6 web page.
Old   November 4, 2020, 03:39
the description is not c++ code, please take a look.
Old   November 4, 2020, 04:16
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Ishan,
This is a recurrent question and yes you can consider it as initial values.
Have a look at this post:
Understanding UniformFixedValue boundary condition
Cheers,
Yann
ishan_ae likes this.
Yann is offline   Reply With Quote
Old   November 4, 2020, 04:48
ishan
geth03 the description is something I can get using foamInfo. Am I right ?
Yann, thank you for pointing it out.
funkySetBoundaryFields - Manipulation of existing field jhertel OpenFOAM Pre-Processing 16 May 18, 2020 07:32
Access to field which is evaluated at the moment Tobi OpenFOAM Programming & Development 6 April 19, 2017 14:09
[swak4Foam] problems with averaging a new field fgarita OpenFOAM Community Contributions 1 October 28, 2016 04:27
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
Demagnetization field jan0385 ANSYS 0 April 12, 2012 10:09
