Accessing controlDict variables in BASH run script |
October 16, 2020, 07:01 |
Callum Guy
Rep Power: 7 |
Hi Foamers,
I would just like to know how to access a variable from the controlDict while writing a BASH runscript. I'm trying to automate a restart in my case should the simmulation fail. I essentially want to do something like: if ( /prossessor*/ "endTime" doesn't exist ): restart solverelse: post-process so hence would need access to the "endTime" variable. Thanks in advance for any help!! Cheers Callum |
October 16, 2020, 07:42 |
Rep Power: 14 |
There are a bunch of shell utilities that you can employ to parse text files. The following would strip out the value of the "stopAt" parameter from controlDict; you should be able to use something like this to do what you need.
#!/bin/bash val=`grep stopAt system/controlDict | sed 's/;//' | tr -s " " | cut -d" " -f2` echo $val Good luck! |
October 16, 2020, 07:50 |
Callum Guy
Rep Power: 7 |
Awesome! Thanks Tobermory!
I was hoping for an elogant OpenFOAM runTime function of some sort but the brute force approach will work nicely! :-) Cheers! |
October 16, 2020, 07:55 |
Rep Power: 14 |
Nae bother. It occurs to me that you are trying to look at the endTime parameter and not the stopAt parameter. This might appear to be a pain since there are usually two lines with endTime in them, viz:
stopAt endTime; endTime 10; Code:
val=`grep endTime system/controlDict | grep -v "endTime;" | sed 's/;//' | tr -s " " | cut -d" " -f2` |
October 16, 2020, 07:58 |
Callum Guy
Rep Power: 7 |
Quite right you are, I was just dealing with that as you posted!!
Should do the trick now I'm sure. Cheers again. |
October 16, 2020, 09:16 |
#6 | |
Mark Olesen
Rep Power: 40 |
In general, you might consider leveraging OpenFOAM utilities as well, since it is quite possible that you otherwise miss includes or pickup other things. For example, Code:
#include "myTimeControls" ... stopAt endTime; // endTime 500; endTime 20; ... endTime 100; Code:
if endTime=$(foamDictionary -value -entry endTime system/controlDict 2>/dev/null) then echo "endTime was $endTime" fi Another convenient command is foamListTimes Code:
latestTime=$(foamListTimes -latestTime) |
October 16, 2020, 10:03 |
Callum Guy
Rep Power: 7 |
Thanks Olesen,
very useful! So am I right to use something like: Code:
endTime = $(foamDictionary -value -entry endTime system/controlDict) directory = "./processor0/" if [ "$(ls -A $directory$endTime)" ]; then# post-processelse# do other stufffi Thanks again! Callum |
October 16, 2020, 10:56 |
Rep Power: 14 |
Very nice Olesen - I should try use those more often, but often I just write my own python or bash scripts to improve my own programming skills.
Callum - the 2>/dev/null sends stderr (i.e. any error messages) into the void (/dev/null), ie prevents them being written to screen. |
October 17, 2020, 10:54 |
#9 |
Rep Power: 14 |
It's funny, since reading your post Olesen, I've used foamListTimes in 3 differenat applications! Just shows how useful this forum can be, to seed new ideas.
October 19, 2020, 06:04 |
#10 | |
Mark Olesen
Rep Power: 40 |
The -rm option for foamListTimes is also fairly convenient to clean out old directories. Previously (when we had a really, really slow) NFS system, I had an adjusted version with -bg (background) option that would avoid some of the lag by doing the following:
Sound like something fun to code up? |
October 19, 2020, 06:14 |
#11 | |
Mark Olesen
Rep Power: 40 |
Tobermory already mentioned the meaning of the stderr redirect. In your case, you should also take advantage of the return code to handle failure. Also not sure why you would use "ls" instead of just checking the directory existence directly. Possible rewrite: Code:
unset hasEndTime procDir="processor0" if endTime=$(foamDictionary -value -entry endTime system/controlDict 2>/dev/null) then if [ -d "$procDir" ] && [ -d "$procDir/$endTime" ] then hasEndTime="parallel" elif [ -d "$endTime" ] then hasEndTime="serial" fi else echo "Error: failed to obtain endTime .. stopping" exit 1 fi # Can check serial/parallel or unset, or simply check anything if [ -n "$hasEndTime" ] then# post-processelse# do other stufffi |
October 19, 2020, 06:19 |
#12 |
Callum Guy
Rep Power: 7 |
I have a question regarding the $(foamListTimes -latestTime) command.
I'm trying to use it to store the latest time in a variable such that I can change the name of the log file for my solver to log.solver$latestTime and hence, OF will allow me to restart the solver after a crash. However, I dont seem to be getting a value assigned to it. My code looks something like this: Code:
endTime=$(foamDictionary -value -entry endTime system/controlDict) directory="./processor0/" if [ "$(ls -A $directory 2>/dev/null)" ]; thenlatestTime=$(foamListTimes -latestTime) mv log.solver log.solver$latestTime runParallel solverelse// mesh // decompose // etc etc...fi Cheers Callum |
October 19, 2020, 06:25 |
#13 |
Callum Guy
Rep Power: 7 |
Also thanks for this again Olesen, you are dragging my BASH scripting kicking and screaming upto standard! Very much appreciated!
October 19, 2020, 06:40 |
#14 |
Rep Power: 14 |
Is it because you are running a parallel run? Remember you need the -processor flag to look in the processorX folders, eg:
latestTime=$(foamListTimes -latestTime -processor) |
October 19, 2020, 06:46 |
#15 |
Callum Guy
Rep Power: 7 |
BINGO!
Thanks again Tobermory! I owe you a drink! :-) Cheers Callum |
October 19, 2020, 09:16 |
#16 | |
Mark Olesen
Rep Power: 40 |
As a gentle reminder, look at what foamListTimes -help splits out. There should be a -processor option, which I think will make sense now. BTW: the 'ls -A' still continues to be a very ugly (bad) way to check for the existence of a directory. |
October 19, 2020, 09:43 |
#17 |
Callum Guy
Rep Power: 7 |
That's fair Olesen, I accept your critisism - an oversight on my part!
I'm sure you can recall when you first ventured into the world of open source code etc, I bet you felt similar in that what seemed so obvious and easy to others never seemed so for you. Especially for us who have no prior experience in computing (I'm a mechanical engineer). It's a lot of information to try and assimilate, and people are destined to ask similar questions in the future. Hopefully, I can pay it forward! As for the 'ls -A' I have indeed tidied that up now. Thanks to you and Tobermory my script is now as functional as it is beautiful! :-) Thanks again both! |
[swak4Foam] How to define boundary condition variables by using previosly defined variables? | pawlo | OpenFOAM Community Contributions | 8 | September 13, 2020 12:37 |
Running OpenFOAM case through shell script (bash) | ilaj | OpenFOAM Programming & Development | 2 | January 28, 2020 14:14 |
How to write the Ansys lic usage Bash script from Windows machine | mg.mithun | Main CFD Forum | 0 | November 28, 2019 10:01 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
How to run PMOVLINK script? | Serkan Cetin | Siemens | 1 | May 1, 2003 13:54 |
