potentialFoam results not written in parallel run
Like Tree1Likes
  • 1 Post By Yann
Old   September 29, 2020, 10:27
Default potentialFoam results not written in parallel run
ishan
ishan_ae is on a distinguished road
Hello.
I am trying to figure out what's going wrong in my potentialFoam run.
I am using this command to run the solver on 30 processors:
mpirun -np 30 potentialFoam -writep | tee potentialFoam.log
It runs all right, but the fields of U,phi and p are never written to the 30 processor directories. The 0 files within the processor directory always remain as they were originally.
But the main 0 directory is updated with the calculated fields.
The domain was decomposed using Scotch.
I have attached here the data from the solver run using MPI and also the controlDict.
I ran the pitzDaily tutorial under decomposed domain and there the results are written to the processor directories.
I am using OF6.
I am not sure what I am doing wrong.
controlDict.txt
potentialFoam.txt
ishan_ae is offline   Reply With Quote
Old   September 29, 2020, 11:00
ishan
I found the reason why it was happening.
I was decomposing the domain into parts with a number greater than the available physical cores.
I have 18 but I was decomposing the domain into 30.
Old   September 30, 2020, 04:36
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Ishan,
I think your error is not related to the number of physical cores.
When running in parallel with mpirun, you have to use the "-parallel" option with your command:
mpirun -np 30 potentialFoam -writep -parallel | tee potentialFoam.log
With the command you wrote in your initial post, you are basically launching 30 times a single process of potentialFoam instead of running it in parallel mode. So the results are probably written at the root of your case instead of the processor directories.
I hope this helps.
Yann
Carlo_P likes this.
Yann is offline   Reply With Quote
Old   October 1, 2020, 04:14
ishan
Hello.
I think that's correct. I got confused with it since this is my very first time using OpenFOAM to work on a big simulation.
Old   October 1, 2020, 05:03
Carlo_P
Carlo_P is on a distinguished road
I can confirm Yann hypotesis.
It is not a problem to run on more processors than you have available. It has nosense, but it is possible.
but, you have to use -parallel.
Otherwise, you are running 30 potentialFoam on 1 processor each.
You can check also on your log file.
In the first lines, you should have 30 different headers and each one tells you that potentialFoam is running on 1 processor.
Carlo_P is offline   Reply With Quote
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
The results difference between parallel and serial run. Hkp OpenFOAM Running, Solving & CFD 2 April 17, 2014 03:26
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 22:36
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
