Ra Miro
Rep Power: 6 ![]() |
Hello.
I would like to model the blood inside an artery (aorta). I'm considering the walls of the artery fixed, and the blood as a newtonian fluid, because the aorta is not too small. This fluid is described by the Navier--Stokes with divergence of the velocity equal to zero. I was using icoFoam solver, but now I realize that icoFoam is for laminar and transient fluid only, but I suppose that the blood inside an artery could be a swirling or turbulent fluid. Do you think icoFoam is a good choice for this model? Or do you suggest to me another solver? |
Rep Power: 20 ![]() |
use pimpleFoam for unsteady and simpleFoam for steadyState flow. If you need to model FSI check out solids4foam on bitbucket.
icoFoam is basically just a stripped down version of pisoFoam -- so the option to add turbulence is removed to learn how solvers are coded in OpenFoam. And pisoFoam is a stripped down version of pimpleFoam...hence pimpleFoam for unsteady flow. icoFoam is however also sufficient in your case. It does however not have many additional options pimpleFoam has, which might be helpful later on. In both of them you can add various viscosity models like Casson and Carreau-Yasuda to model non newtonian effects of blood flow. For more complicated things like seperation effects inside blood vessels etc in certain diameters you'd need to switch to multiphase eulerEuler variants. For example red blood cells sticking to walls etc if you want to model them as a second continuous phase. Keep in mind that blood is mostly laminar and can be non Newtonian in behavior. Turbulence is possible, but you shouldn't use the simple Re number. There are variations for pulsating flow...so it might be lower than the typical ~2300 for pipes. If i remember correctly ~900. |
#3 | |
Matvey Kraposhin
Rep Power: 21 ![]() |
Please, write if you have any issues about compilation or running. I also have MSc students who can help you to manage with setup.
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
Ra Miro
Thanks mkraposhin, I going to revise your work.
blood flow, icofoam, navier stokes equations |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Solver consists of DPM, P1 radiation, k-E model | mvee | OpenFOAM Pre-Processing | 0 | March 23, 2015 01:01 |
1-D model for blood flow in artery | Robert Lichtenshtein | Main CFD Forum | 1 | December 19, 2002 15:33 |
