Ignition strength meaning ??
Like Tree5Likes
  • 1 Post By Gioralex
  • 2 Post By dlahaye
  • 1 Post By dlahaye
Old   September 13, 2020, 13:00
Default Ignition strength meaning ??
Giorgio Alessandroni
Gioralex is on a distinguished road
Hello Foamers,
I would like to know the meaning of ignition strength in combustionProperties in kivaTest
tutorial. What does it mean ? How does it influence the results ? What's the correct
value ?
Any help is appreciated.
Thank you in advance, regards
Vitor Monteiro likes this.
Gioralex is offline   Reply With Quote
Old   September 13, 2020, 16:30
Domenico Lahaye
dlahaye is on a distinguished road
Combustion is started by ignition source. The amplitude of this source is the ignition strength. Its value is application dependent.
alainislas and Gioralex like this.
dlahaye is offline   Reply With Quote
Old   September 13, 2020, 18:01
Hi dlahaye,
thanks for the rapid answer. I'm using XiEngineFoam to simulate a premixed combustion of a methane-air mixture in engine which is very similiar to the one of kivaTest. The compression ratio is 10. I've created my own structured mesh with Hypermesh (Altair). So how do I know the correct value of the ignition strength for my case? For example in the kivaTest tutorial it is set to 4.
Thanks in advance for any help. Regards
Old   September 14, 2020, 03:47
Domenico Lahaye
Unable to answer this. Ask around in environment in which your problem originates. Or look into publication on engineFoam.
Gioralex likes this.
Old   September 18, 2020, 08:35
Default Combustion questions
Hello Foamers,
I moved on and now I have some new questions about XiEngineFoam:
1. As you can see from the files in the attachment, I changed the fuel from isoOctane to methane. I used the tool adiabaticFlameT and from the thermo.log file I have found the correct values of the janaf coefficients to put in the thermophysicalProperties for fuel, oxidant and burntProducts. Is it correct ?
2.I have also found in literature the Sutherland coefficients As and Ts for the transport for fuel and oxidant but not for the burntProducts. How can I determine this values ? How do they change the results ?
3.I have run the simulation of a premixed stochiometric combustion with XiEngineFoam. If I would change the equivalence ratio what I have to do ? Is it enough to change the equivalenceRatio in the combustionProperties or I have to change something else in thermophysicalProperties ?
Thank you in advance for your support. It means a lot for me and for my thesis.
Giorgio
File Type: zip combustionProperties.zip (896 Bytes, 21 views)
Old   June 9, 2023, 17:15
Dilay
dguleryuz is on a distinguished road
Originally Posted by Gioralex View Post
Hello Foamers,
Giorgio
Hello Giorgio,
I am trying to use XiFoam. Could you please share how did you use the tool adiabaticFlameT?
Thanks and regards.
dguleryuz is offline   Reply With Quote
Ignition and flame propagation with XiFoam for a few meters long comput. domains Gloq OpenFOAM Running, Solving & CFD 1 February 21, 2023 13:22
Ignition source modelling in CONVERGE JVJ CONVERGE 5 March 4, 2020 08:09
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 23:08
how does the ignition model initiate main combustion mepgzzi Siemens 0 June 23, 2012 15:32
Ignition modeling Julie Polyakh Siemens 0 May 20, 2004 09:05
