Modified Bessel Functions
Like Tree1Likes
  • 1 Post By saumavadey
Old   September 12, 2020, 13:53
Default Modified Bessel Functions
Saumava Dey
saumavadey is on a distinguished road
Are the modified Bessel Functions of Type 1 and Type 2 ie. I0, I1 and K0, K1 are available inside OpenFOAM's latest version (OpenFOAM v2006)?
saumavadey is offline   Reply With Quote
Old   September 12, 2020, 15:54
Domenico Lahaye
dlahaye is on a distinguished road
OpenFoam has boost (see boost.org) and boost in turn has modified Bessel fcts.
dlahaye is offline   Reply With Quote
Old   September 12, 2020, 16:19
Saumava Dey
Hello dlahaye!
Thank you very much for your answer.
As I am a beginner in OpenFOAM programming, can you please guide me through the steps to call any function from 'BOOST' to my code in OpenFOAM.
Do I need to install the latest version of BOOST in the same directory where I have OpenFOAM installed on my laptop?
Old   September 12, 2020, 16:23
Domenico Lahaye
See examples on boost.org Good luck.
Old   September 18, 2020, 16:14
Saumava Dey
Hello Foamers!
I have stated using the Modified Bessel Function from boost in my code as follows:
scalar T = this->db().time().value();
scalar P = i*log(2.0)/T;
scalar Q0 = sqrt(P);
scalar K0_0 = cyl_bessel_k(0, Q0);
While compiling it gives the following error:
error: ‘cyl_bessel_k’ was not declared in this scope scalar K0_0 = cyl_bessel_k(0, Q0);
note: suggested alternative: In file included from myFunctionFvPatchScalarField.C:18:0: /usr/include/boost/math/special_functions/bessel.hpp:587:81: note: ‘boost::math::cyl_bessel_k’
inline typename detail::bessel_traits<T1, T2, policies :: policy<> >::result_type cyl_bessel_k(T1 v, T2 x)
I am not being able to figure out the problem. I seek help in this regard.
Old   September 28, 2020, 20:00
Default Bessel function for non-integer orders
Esmaeel Eftekharian
Esmaeelef is on a distinguished road
Hello everyone,
I have seen that OpenFOAM provides bessel functions of orders 0 and 1, but, I need to use a Bessel function of non-integer order in my code. Does OpenFOAM have a function in this regard?
Esmaeelef is offline   Reply With Quote
Old   September 29, 2020, 03:50
Saumava Dey
I have seen examples of Bessel function evaluation of non-integer orders using the Boost library functions. You can try using them.
Esmaeelef likes this.
function
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Problem while compiling modified simpleFoam solver mattiafc OpenFOAM Programming & Development 0 May 26, 2020 21:01
[Commercial meshers] CCM+ Mesh Conversion Ingenieur OpenFOAM Meshing & Mesh Conversion 17 February 2, 2014 10:34
Working with Bessel functions? farhan CFX 0 March 25, 2009 17:42
Modified wall functions Stephanie Main CFD Forum 0 May 14, 2007 04:15
