LES simulation and wall modeling
Like Tree5Likes
  • 1 Post By joegi.geo
  • 3 Post By HPE
Old   August 21, 2020, 19:32
Default LES simulation and wall modeling
milad1990 is on a distinguished road
Hi Foamers!
I am trying to use WALE and Smagornsky for simulating flow around cylinder. My Re is 10^4 and my fluid is water. I have U, P, nut, k files in my /0 folder. I know that for turbulent simulations in order to capture fluid properties near wall we have two ways:
1- Using very fine mesh near wall.
2- Using wall modelings and a fair mesh near wall.
For case 2, I know that for boundary conditions I have to use wall functions like (nutUSpaldingWallFunction) or (nutUWallFunction) or etc for "nut", and (kLowReWallFunction) or (kqRWallFunction) for "k".
But I do not know exactly what should I consider for wall boundary condition for "nut and "k" in case 1. (of course no wall modeling but what instead?)
Thank you in advance for your response.
milad1990 is offline   Reply With Quote
Old   August 21, 2020, 23:12
joegi
joegi.geo is on a distinguished road
Niether of the models use k. nutUSpaldingWallFunction is fine in both cases.
By the way, wall modeling LES does not strictly mean that you can use a coarse mesh close to the wall. Your y+ can be larger than 30, but you still need to have a low deltaX+ and deltaZ+, and this translates in fine meshes (thou coarser than wall resolving LES).
milad1990 likes this.
joegi.geo is offline   Reply With Quote
Old   August 22, 2020, 11:31
Dear Joegi.geo
Thank you so much for your response.
Yes. you are right about deltaX+ and deltaZ+. Also you said, when we use wall modeling, we do not necessarily need to prove Y+<1. But suppose that we need to do a simulation without wall modeling. So what should we use for "boundary condition" for "k" and "nut" on walls (cylinder)?
Also I am using templates from wiki open-foam (wiki.openfoam.com/Vortex_shedding_by_Joel_Guerrero_3D)
and they use both "nut" and "k" as boundary conditions for LES in 0/ folder.
Thank you so much
Old   August 22, 2020, 12:44
joegi
k is not computed for wale and smagorinsky. You can erase that file safely. For nut use nutUSpaldingWallFunction, it is y+ insensitive.
Old   August 22, 2020, 13:19
Thank you dear Joegi.geo
I think from what you said, for "nut" boundary condition on walls, we should always use a wall function. I am looking for a method to not use a wall function.
Best
Old   August 22, 2020, 13:47
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Sometimes OpenFOAM namings are a bit misleading. For y+<5 grids, nut and k wall functions automatically switch to non-wall function behaviour in a stepwise manner. Have a look at their implementations.
For example, for y+<5, nutUSpalding is a safe and preferable one (within the derivation assumptions of Spalding model expression) because it is smooth between viscous and inertial layers, but you can use any nut wall function, because for such fine grids the selected wall function does not apply/compute the wall function expressions - but applies viscous sublayer analytical expressions as if no wall function is being used. Most do switch in stepwise manner by default, but you can also specify exponential or binomial smooth blending.
The same argument applies to epsilon and omega wall functions as well.
Yet the other way around is not possible. For example, nutLowReWallFunction (which is not a wall function, but a wrapper class - another name for either fixedValue or zeroGrad BC) should not be used for y+>30 grids.
acgnipper, Gang Wang and milad1990 like this.
HPE is offline   Reply With Quote
Old   August 22, 2020, 15:53
Hi HPE
That was a very good guidance.
Thank you so much
Best
To calculate wall shear stress in of210 for les simulation suryawanshi_nitin OpenFOAM Post-Processing 44 August 3, 2018 14:01
OpenFoam 4.1: interDyMFoam LES Simulation for hydro turbine in river pi__sec OpenFOAM Running, Solving & CFD 13 July 19, 2017 05:08
Grid difference between wall modeled LES and wall resolved LES hityangsir Main CFD Forum 9 April 17, 2015 12:59
LES wall function for a cylinder simulation mike_ OpenFOAM Running, Solving & CFD 0 January 12, 2015 10:54
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
