interIsoFoam runs for maxCo = 10 but not maxCo = 2.5
Like Tree2Likes
  • 2 Post By Bloerb
Old   August 20, 2020, 10:27
Question interIsoFoam runs for maxCo = 10 but not maxCo = 2.5
Shannon Leakey
scleakey is on a distinguished road
OpenFOAM uses implicit methods so I thought I would see how far I could push the Courant number before it crashes - isn't the point of implicit methods to get large Courant numbers?
I'm running a multiphase case with interIsoFoam on six processors. Keeping everything else the same, I tried different values for maxCo...
1.0
2.0
2.3
2.5 crashed at t = 0.02 after high residual for p_rgh
2.7 crashed at t = 0.02 after high residual for p_rgh
3.0 crashed at t = 0.02 after high residual for p_rgh
5.0
10.0
20.0 crashed at t = 1.31, not sure exactly why
I don't understand how it ran for maxCo = 10 (with very sensible results) but crashed for maxCo = 2.5? I realise there are lots of reasons that it might crash but I thought that decreasing the Courant number would make it more stable, not less
Has anybody else experienced this?
scleakey is offline   Reply With Quote
Old   August 20, 2020, 16:07
Bloerb will become famous soon enough
Implicit methods while allowing you to use Co>1 have a smoothing effect on the solution. So high pitched oscillations with a frequency higher than your time step will be smoothed out. This usually means a loss in accuracy. Imagine a sine wave where you only calculate the values between peaks. It is not unreasonable that the same effect applies to errors of said frequency. So depending on your problem this can increase stability in a certain range.
arjun and scleakey like this.
Bloerb is offline   Reply With Quote
Old   August 21, 2020, 05:43
Shannon Leakey
Thanks for your reply I think I understand what you mean
courant number, implicit, interisofoam, maxco, stability
from interFoam to interIsoFoam brammekeuh987 OpenFOAM Running, Solving & CFD 2 April 18, 2020 08:52
maxCO doesn't work MagicCFD OpenFOAM Running, Solving & CFD 0 May 14, 2019 03:02
[blockMesh] Another cylinder question bendel_boy OpenFOAM Meshing & Mesh Conversion 5 January 6, 2015 06:09
icoFoam continuity error tellico OpenFOAM 1 September 21, 2011 04:43
weird error during blockMesh SePe OpenFOAM 1 October 25, 2010 11:31
