August 13, 2020, 04:12 |
Radiation in large scale fire
Roman
Rep Power: 13 |
Hello! I am modelling radiation of large scale fire. The burner is a cylinder of 150 m height.
The parameter to be found is 'G'. Radiation model -fvDOM, firefOAM.The running stops or does not start at all when the domain size exceeds some values. These are 120x70x150 meters, nPhi, nTheta=5, decomposed for running at 8 cores. It just writes 'process killed'. One must decrease number of angles or cells. I would like to know what kind of restriction works here. For the truth, domain needed size is two times much. Thanks/ |
August 14, 2020, 12:44 |
Chris DeGroot
Rep Power: 18 |
You are most likely running out of memory, since the FVDOM model requires one field for each of the angular directions. You either have to reduce the angular discretization or obtain more memory.
August 15, 2020, 04:08 |
Roman
Rep Power: 13 |
Thanks. You are absolutely right. I have looked at system monitor. All 8Gb is busy. Without even a small residual.
Decomposition Methods: which ones are best for large scale simulations? | misakagan | OpenFOAM Running, Solving & CFD | 9 | December 14, 2023 03:36 |
UDF value to large for defined data type | Anna73 | Fluent UDF and Scheme Programming | 9 | September 30, 2018 23:18 |
Large Scale CFD Simulations | maybee | Main CFD Forum | 3 | May 30, 2014 18:46 |
What method use to modelate a side-entry impeller in a large scale mixing tank? | fcabrales | Main CFD Forum | 0 | January 29, 2010 15:24 |
About Large Scale Domains | Swarup | FLUENT | 10 | October 5, 2006 00:09 |
