July 28, 2020, 02:51 |
Pressure coefficient of simplefoam
Bayaraa
Rep Power: 6 |
I am using steady state, simplefoam. Therefore, from my result i can only acquire pressure plot values on only one time. I have wanted to see the pressure fluctuation on each time step. How do i see time plot of pressure or it is not possible because of steady state ?
July 30, 2020, 06:58 |
Rep Power: 14 |
Well, as you point out, simpleFoam is a steady state solver, so you cannot see variations in time. You can, of course, monitor the variations over each iteration step - using a probe, for example. I suggest reading section 6.3 of the user guide (https://cfd.direct/openfoam/user-gui...#x33-2580006.3), and check out the tutorials - that should give you some ideas on how to do this.
However, if you are talking about real "pressure fluctuations", i.e. turbulent fluctuations in pressure, then you need to think rather more carefully about your solver approach. Clearly you need a transient solver. You probably also need to be running LES, which is a whole new conversation (and solver). Good luck! |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
[swak4Foam] Swak4Foam/GroovyBC for total pressure in simpleFoam | fivos | OpenFOAM Community Contributions | 5 | February 14, 2014 11:51 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
